Freeze plugs
jlaird
Safest way is to drill a hole in em and pull em out.
replace with a hammer gentle like and then set in the center.
Platinum
Agreed. Drill 'em and lever 'em out. Tap in the new ones with a ball-peen hammer (the 'flat' end). This is the ONE place I use the dreaded Permatex #2, BTW.
Marvin Gruber Auto Zone $15 freeze plugs Austin Healey 3
F Brass freeze plugs BJ8 Austin Healey 4
Rob Glasgow Brass Freeze Plugs Austin Healey 7
Rob Glasgow Sealant for freeze plugs Austin Healey 3
M Healey 100-4 Freeze Plugs Austin Healey 1
J Core plugs/freeze plugs Austin Healey 7
TR6oldtimer TR6 Casting plugs aka freeze plug size TR6 Triumph 6
lbc_newbie Brass freeze plugs for 1275... Spridgets 20
DNK freeze Plugs Triumph 8
2wrench Tapping in the freeze plugs pics Triumph 1
B Freeze plugs? MG 4
I TR6 Freeze [casting] engine plugs, 69 TR6 Triumph 8
A TR6 TR6-freeze plugs , Gasket , Oil pump, Questions? Triumph 2
4 T-Series TD Freeze plugs MG 0
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
SherpaPilot TR6 Questioning a Freeze Plug Triumph 3
tomshobby Have you checked your anti-freeze? Spridgets 1
Boggsy64 MGB Freeze plug removal MG 7
T TR2/3/3A TR3 head core plug [freeze plug] Triumph 6
tahoe healey Anti-freeze Austin Healey 10
tony barnhill '85 XJ6 Losing Anti-Freeze Jaguar 21
HEALEYJAG Popped freeze out plug 100 le mans Austin Healey 3
martx-5 TR2/3/3A Freeze Out Plug...TR3 Triumph 3
Tinkerman TR2/3/3A 3A freeze plug on the back of the head. Triumph 4
B Leaky Freeze Plug Austin Healey 33
P freeze plug blew out MG 27
S Anti Freeze mixture Austin Healey 3
T Starter Motor Freeze? Triumph 2
P Freeze Plug Blues Austin Healey 12
Morris Grrrrrrrrrr! Stuck freeze plug! Spridgets 21
miranda anti-freeze?? Austin Healey 2
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
kodpkd Spark Plugs Austin Healey 3
L TR4/4A spark plugs Triumph 9
A MGB Welsh plugs MG 9
HighAltitudeTR3 T-Series Why are there nuts in my core plugs?! MG 8
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
AUSMHLY When to replace spark plugs Austin Healey 1
