Brass freeze plugs for 1275...
Why brass?
OK, I just assume that I'll need to rebuild my engine before mine will corrode.
They are sometimes referred to as welch plugs.
R
RonMacPherson
Any good parts supplier, Napa, CarQuest, etc. that carries Dorman products should have them on hand, or available from their local warehouse.
Might do a search for Dorman Hardware...
aeronca65t
Yes, steel one are avialable easily (as mentioned, Dorman and others make them as well as in the Moss catalog).
But *brass* ones might be another story.
I'm sure you could have them made up, but I can't recall ever seeing them in a 1275 engine myself.
The steel ones in my MGB are 40 years old...still seem to be OK.
Dug
Ed,
How many do you need? I do have them. Someone will chime in and also tell you that "if" the engine is apart you could simply tap the holes 1/8" NPT and use brass, stainless or zinc plated pipe plugs. But if you need brass press in style plugs I can help.
Dug
Sounds like the machinist may be a bit A series iffy, the 1275s have bullit proof freeze/core plugs, now if we were talking about 948/1098 or a MGB I could buy that, but brass freeze plug, whats up with that, sure he didn't say oil galley plug, if so I tap for NPT plugs as well.
Dug
I'm thinking they are asking for galley plugs. That's what I sent Ed.
If I'm wrong then Ed has some galley plugs he will not need,but a bigger problem with the shop his engines at.
Dug
But wouldn't a machine shop have a large assortment of brass plugs on hand?
Most engines beside our ours don't use brass plugs, Cheeeeeevies :smile: :smile: use little cup plugs. Actually what they are you'd never find today anywhere but a British vendor the orgignal are tapered brass plugs, I never reinstalled them, always used NPT plugs, that habit comes form my racing background.
OK... the the machine shop I use has several bins of them, but they do work on many vintage and antique engines both foreign and domestic. I just assumed that the plugs were common enough for everyone to keep on hand.
Dug
I’m allergic to moss so I couldn’t say. However you should have a Fastenal store nearby and the part number(s) you would want to look for are
73390 for stainless
94132 for zinc plated steel
80743 for brass
That's a good route to go, you will have a choice as the press in ones are on their way.
Dug
lbc_newbie
lbc_newbie
I think I've made it obvious that I'm not an experienced engine builder. I appreciate all the feedback. Still looking for a supplier for the NPT product. I don't see anything specific to the A Series for expansion plugs. Any help is appreciated in providing size, quantity and location of these.
Billm
Ed
Any nut & bolt house will have what you are looking for (threaded plugs).
"HiStrength Bolt" in Kent has a great selection and I can pick-up anything you want when I stop by there (often).
BillM
Dug
Ed,
Opps, well you will now have a set of galley plugs. From your last post you do need Expansion plugs, freeze plugs, soft plugs and or welch plugs to use just a few different names for the same thing.
If the shop tells you there are 5, three on the side and two at the back then expansion plugs "are" what you needed. Ron called it correctly. Steel (zinc plated) is 100% good.
Dorman is a common brand, size is 1-21/64" Dorman part number is 555-072. Napa (seal power) part number is 3812127. Even easier to come by.
Dug
F Brass freeze plugs BJ8 Austin Healey 4
Rob Glasgow Brass Freeze Plugs Austin Healey 7
A For Sale Mystery brass intake manifold Other British Classifieds 0
S TR2/3/3A brass fitting from a steel brake line Triumph 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
S TR2/3/3A lower small brass bushing Triumph 13
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
M Brass F type radiator shell build Restoration & Tools 11
M TR2/3/3A O/D brass cap leaking Triumph 5
K TR2/3/3A Numbered brass plates on the firewall above the battery? 59 TR3A Triumph 4
M TR2/3/3A What is my radiator made of? Brass? Triumph 6
GTP1960 TR2/3/3A Re-tapping a zerk in a brass trunnion housing? Triumph 17
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
GTP1960 TR2/3/3A Brass /delrin bushings on rear spring shackle? Triumph 3
Jim_Gruber Removing brass bushings from spindle Spridgets 9
5 brass steering box bushing Austin Healey 3
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
DNK Brass Tags Triumph 6
P Engine brass Triumph 1
Nelson Brass manifold nuts? Spridgets 5
angelfj1 Brass Body Tags Triumph 2
rlich8 Brass Carb Dampers? Triumph 6
58Custom Question re: brass plugs in deck of cylinder head. Spridgets 7
C 45 shipped in the USA brass over flow, Polished Spridgets 5
NutmegCT paint a brass radiator? Restoration & Tools 7
tinman58 TR2/3/3A Brass tags TR3 Triumph 8
I TR6 TR6 frozen brass lower trunion Triumph 3
S TR2/3/3A brass bushing tr3 Triumph 6
19_again brass or steel synchro rings MG 7
gsalt57tr3 Brass body tags Triumph 16
I zenith stromberg float brass plug removal help Triumph 14
rlandrum Finishing the Brass Trunions Triumph 26
L Shinny Brass top radiator Triumph 4
6 Question re: Welch Brass Radiator Austin Healey 5
Luke_Healey Throttle cable brass piece stuck in cable stop. Spridgets 7
timbn2 Metal AND Brass door hinges...huh????? Austin Healey 5
J Brass in steering box - GL5 danger? Triumph 7
H Austin Healey 100 S Original brass plate on Ebay Austin Healey 9
SCguy best cleaner for brass connectors? Triumph 7
PeterK TR2/3/3A TR3A brass body plate Triumph 4
3 BMW corporate brass comes to visit. Triumph 10
tahoe healey brass dampers Austin Healey 8
tahoe healey Brass nuts [ Manifold Hardware ] Austin Healey 6
B Brass brake cylinder sleeves Jaguar 6
