Metal AND Brass door hinges...huh?????
timbn2
timbn2
aluminum, huh... weird. not these however, one set is definatly brass (at least colored) and feel lighter than the others which are magnetic (metal).
GregW
Platinum
The BJ7 & 8s had different hinges made from aluminum. I’m not sure what material was used on the hinges for the earlier cars.
roscoe
I have a '56 BN-2 and the door hinges are steel all around.
There are several different style hinges, the BN-2 hinges are different from the BN-1. I don't know where the serial number break was, but you can look at the AH shop manual and see the differences.
Jon
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
D Made a sheet metal break. Restoration & Tools 5
J Door Draught Metal Clips Austin Healey 4
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
F Off Topic metal forming for a friend Triumph 25
N Spridget sheet metal Spridgets Classified 0
steveg TR6 Metal Dash - does anyone make one? Triumph 13
J For Sale Triumph TR 2/3MISC sheet metal parts Triumph Classifieds 1
Busted knuckles TR2/3/3A Sheet metal question, Triumph 5
jfarris TR2/3/3A Metal washers for SU H6 float bowls Triumph 1
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
red57 Metal prep of chassis after repairs and shot blasting Austin Healey 5
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
S TR2/3/3A busted through to bare metal Triumph 18
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
SpeedyG TR4/4A TR4 vs. TR4A metal dash panel Triumph 5
S TR2/3/3A were the 2 metal gas lines connect Triumph 18
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
S TR4/4A Metal facia trashed Triumph 3
R metal adhesives Austin Healey 12
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
C Recommendations on where to send my 1954 BN1 for metal work? Austin Healey 13
T TR2/3/3A TR3A Sheet Metal Piece Needed Triumph 2
I General TR Pot metal rechroming Triumph 7
T TR2/3/3A Requesting some Pictures for metal work Triumph 9
MTribe TR6 Can you identify these metal shavings in the oil? Triumph 32
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
Brinkerhoff MGA metal work details MG 18
certifiedcarnut Spridget master cylinder cap, metal Spridgets 8
S TR2/3/3A Odometer gears for the early pot metal speedometer Triumph 27
Scot1966 TR6 TR6 sheet metal Triumph 3
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
T TR4/4A Fabricating a metal panel in between the fuel tank and cockpit Triumph 6
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
JPSmit New fun tool review - metal tumbler Restoration & Tools 6
R Simple question about metal Spridgets 18
Hap Waldrop King Tri metal Bearing MG 10
doc50 Best Method to weld sheet metal repair panels in... Triumph 10
S TR2/3/3A tr3 metal fuel lines Triumph 1
L Bugeye door pocket metal trim Spridgets 0
G TR2/3/3A Tropical metal fan for TR3 Triumph 4
S TR2/3/3A those metal button trim pieces tr3 Triumph 5
J Metal work restoration of a TR3A Restoration & Tools 1
J TR2/3/3A 1959 TR3A metal work restoration. Triumph 9
D austin healey sheet metal Austin Healey 2
M sheet metal thickness Spridgets 3
