Question re: Welch Brass Radiator
62BT7
I was surfing Denis Welch's website and noticed that he's offering "Uprated Radiators." Based on the description it looks like the products are new (perhaps reconditioned, hard to tell) radiator frames with a much better core, I assume a 4 tube set up, etc. That's all to be expected, no surprises given the well known Healey overheating problems. Here's the question: He also offers the same unit in "Brass" for a slight increase in cost. Is a brass unit superior to the standard? If so, why? Given Welch's expertise I can't imagine it'd be offered if there was zero benefit over the standard unit. Any ideas? Just curious.
Keoke
62BT7, I have no reason to believe that there are any significant benefits of a Brass unit over that of a copper one. IMOP the price increase for the brass unit is simply the result of costs. It costs significantly more to produce Brass which is not found in a virgin form like copper. Similarly, the current world economic state has depreciated the cost of copper.--Fwiw-Keoke??
Dave Russell
Yoda - R.I.P
First off, what is a brass radiator?
Conventional radiators usually have brass top & bottom tanks & brass tubes. The tubes pass through copper fins which are soldered to the tubes where they pass through the holes in the fins.
Brass is structurally stronger than copper, thus it's use in the tanks & tubes. Copper has more thermal conductivity than brass, thus it's use for the fins.
If "brass radiator" means that the fins as well as the tubes are brass, the only possible advantage would be more mechanical strength. The down side would be less cooling effeciency for the same radiator size & layout.
It appears that with either type fins, the fin to tube solder bond deteriorates over time, reduces heat transfer, & reduces the cooling effeciency. Because of this, a new radiator of the same exact materials & construction will often give better cooling.
You could ask DW why they are offering "brass radiators" & what?
To ramble on a bit:
Conventional radiators of soldered construction have become an environmental problem. With millions of radiators to be disposed of, the considerable amount of lead used in the soldered construction is a "hazardous" material that creats disposal & recycling problems.
To combat the environmental problems, to reduce weight, & to reduce costs, most manufacturers have switched to aluminum radiators which don't require lead solder. Additionally, the top & bottom tanks are often plastic which is mechanically clamped to the tube assembly.
There are some high quality after market aluminum radiators available which are of all braised construction, lighter in weight, & very sturdy. Because aluminum has lower thermal conductivity, aluminum radiators must have quite different tube designs, better fin designs, & generally much different from their brass/copper counterparts.
Ralph F.
Member
Just my two cents, but perhaps a "brass radiator" is a version whereby the top tank is done in shiny unpainted brass, as opposed to the standard black painted radiator. Although non-standard, I have seen cars with this "upgrade", supposedly to add some pizzazz or "bling" to the engine compartment.
Keoke
Naw Ralph,what is generally seen is not an upgrade. All the stock radiators have brass upper and lower tanks. It just depends on whether you want something else to polish, if you do then you strip the paint and polish the top tank.--Fwiw--Keoke
GregW
Platinum
Maybe the extra cost is to have one of the Welsh lads do the deed.
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
R TR6 Starter wiring question Triumph 6
K TR2/3/3A TR-3B carb question Triumph 13
