TR2/3/3A Brass /delrin bushings on rear spring shackle?
GTP1960
Hey
anyone have an opinion on the advantage of Brass /delrin bushings on rear spring shackle compared to the regular rubber ones?
i'm more interested in a comfortable ride vs. performance, if That makes any difference.
also is there a better option to the silent bloc in the spring front eye?
( though I hate the thought of removing the old one)
thx
TR3driver
Great Pumpkin - R.I.P
Unless you are going racing or running really wide tires, I'd stick with the stock bushings. No sense giving up ride quality for a miniscule improvement in handling if ride quality is more important to you.
GTP1960
GTP1960
Thx Randall
i' m going to stick with the OEM shackle bushings (not to mention the appeal of $8 bucks. Vs. $80.)
now I'm trying to decide if removing the old silent blocs from the front spring eye is worth the trouble, as they are not in terrible shape.
( they appear to be just a difficult to remove as the steerage linkage ones though)
do you know an easier way to remove them?
my technique has been :
drilling the rubber, sawing the metal housing & beating the day lights out of it.
TR3driver
As I recall, I pressed out the center sleeve (which was broken loose from the rubber so came out easy), then just pressed the new Silentbloc into place, forcing the old one out. The first time I didn't have a hydraulic press, so I did the same thing using threaded rod and various other pieces of "furniture". Possibly a 1.5" pipe nipple to receive the old outer sleeve as it came out, and a 1" pipe coupling to press against the outer sleeve of the new Silentbloc but I don't really recall offhand. I keep a pile of "found" objects like old bearing races and such for such purposes so it might have been one of those instead of a pipe fitting. Obviously, you don't want to press against the inner sleeve of the new one, as that might break the rubber/steel bond.
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
S TR2/3/3A brass fitting from a steel brake line Triumph 2
S TR2/3/3A lower small brass bushing Triumph 13
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
M Brass F type radiator shell build Restoration & Tools 11
M TR2/3/3A O/D brass cap leaking Triumph 5
K TR2/3/3A Numbered brass plates on the firewall above the battery? 59 TR3A Triumph 4
M TR2/3/3A What is my radiator made of? Brass? Triumph 6
GTP1960 TR2/3/3A Re-tapping a zerk in a brass trunnion housing? Triumph 17
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
F Brass freeze plugs BJ8 Austin Healey 4
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
Rob Glasgow Brass Freeze Plugs Austin Healey 7
Jim_Gruber Removing brass bushings from spindle Spridgets 9
5 brass steering box bushing Austin Healey 3
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
DNK Brass Tags Triumph 6
P Engine brass Triumph 1
Nelson Brass manifold nuts? Spridgets 5
angelfj1 Brass Body Tags Triumph 2
rlich8 Brass Carb Dampers? Triumph 6
58Custom Question re: brass plugs in deck of cylinder head. Spridgets 7
C 45 shipped in the USA brass over flow, Polished Spridgets 5
NutmegCT paint a brass radiator? Restoration & Tools 7
tinman58 TR2/3/3A Brass tags TR3 Triumph 8
lbc_newbie Brass freeze plugs for 1275... Spridgets 20
I TR6 TR6 frozen brass lower trunion Triumph 3
S TR2/3/3A brass bushing tr3 Triumph 6
19_again brass or steel synchro rings MG 7
gsalt57tr3 Brass body tags Triumph 16
I zenith stromberg float brass plug removal help Triumph 14
rlandrum Finishing the Brass Trunions Triumph 26
L Shinny Brass top radiator Triumph 4
6 Question re: Welch Brass Radiator Austin Healey 5
Luke_Healey Throttle cable brass piece stuck in cable stop. Spridgets 7
timbn2 Metal AND Brass door hinges...huh????? Austin Healey 5
J Brass in steering box - GL5 danger? Triumph 7
H Austin Healey 100 S Original brass plate on Ebay Austin Healey 9
SCguy best cleaner for brass connectors? Triumph 7
PeterK TR2/3/3A TR3A brass body plate Triumph 4
3 BMW corporate brass comes to visit. Triumph 10
tahoe healey brass dampers Austin Healey 8
tahoe healey Brass nuts [ Manifold Hardware ] Austin Healey 6
B Brass brake cylinder sleeves Jaguar 6
