Popped freeze out plug 100 le mans
HEALEYJAG
Popped a freeze out plug on my first day on my newly restored 100 le mans .....The car did not overheat..I am concerned with other issues.. Any ideas or thoughts I should be concerned about?
Thank You:
Pete
Keoke
Thank You:
Pete
Hi Pete this is not an uncommon problem Probably just a case of the plug being marginally installed. There are rubber type expansion plugs you can install temporarily until you can reinstall the metal plug.---Fwiw--Keoke
HEALEYJAG
HEALEYJAG
Thanks for making me feel a little better..the engine was rebuilt by a previous owner who is deceased so I am unable to document half of the work.. I have done the other half over the past two years...Have not had a plug pop on any of the other dozen or so Healeys I have owned......will try not to expect the worse.
Pete
Dave Russell
Yoda - R.I.P
HEALEYJAG said:
Popped a freeze out plug on my first day on my newly restored 100 le mans .....The car did not overheat..I am concerned with other issues. Any ideas or thoughts I should be concerned about?
Thank You: Pete
If one plug popped out I would VERIFY that the others are properly installed. The Fours used a domed type plug instead of the later cupped plugs.
When properly installed, the plug domes should have a very noticeable flat spot or even a dimple in their centers. If in doubt, they should be "tightened". There are five on the RH side of the block & two on the back side.
You were lucky this time, if it happens again there could be serious engine damage.
simon1966 Hard top for 4 seater just popped up on local Craig's List Austin Healey 2
W Chrome Windshield Trim Popped Off Jaguar 2
CJD TR2/3/3A Popped the top on the TR2 Triumph 13
L Popped out of second gear! Austin Healey 4
T My wife popped my balloon. Triumph 4
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
SherpaPilot TR6 Questioning a Freeze Plug Triumph 3
Marvin Gruber Auto Zone $15 freeze plugs Austin Healey 3
F Brass freeze plugs BJ8 Austin Healey 4
tomshobby Have you checked your anti-freeze? Spridgets 1
Rob Glasgow Brass Freeze Plugs Austin Healey 7
Rob Glasgow Sealant for freeze plugs Austin Healey 3
Boggsy64 MGB Freeze plug removal MG 7
M Healey 100-4 Freeze Plugs Austin Healey 1
J Core plugs/freeze plugs Austin Healey 7
TR6oldtimer TR6 Casting plugs aka freeze plug size TR6 Triumph 6
lbc_newbie Brass freeze plugs for 1275... Spridgets 20
DNK freeze Plugs Triumph 8
T TR2/3/3A TR3 head core plug [freeze plug] Triumph 6
tahoe healey Anti-freeze Austin Healey 10
tony barnhill '85 XJ6 Losing Anti-Freeze Jaguar 21
2wrench Tapping in the freeze plugs pics Triumph 1
B Freeze plugs? MG 4
I TR6 Freeze [casting] engine plugs, 69 TR6 Triumph 8
martx-5 TR2/3/3A Freeze Out Plug...TR3 Triumph 3
Tinkerman TR2/3/3A 3A freeze plug on the back of the head. Triumph 4
B Leaky Freeze Plug Austin Healey 33
P freeze plug blew out MG 27
S Anti Freeze mixture Austin Healey 3
T Starter Motor Freeze? Triumph 2
P Freeze Plug Blues Austin Healey 12
Morris Grrrrrrrrrr! Stuck freeze plug! Spridgets 21
Morris Freeze plugs Spridgets 2
A TR6 TR6-freeze plugs , Gasket , Oil pump, Questions? Triumph 2
miranda anti-freeze?? Austin Healey 2
4 T-Series TD Freeze plugs MG 0
C MGB New plug wires and distributor cap MG 10
CARSINC Spark plug thread size Spridgets 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Carlbanan56 MGB Manifold plug MG 5
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Spark plug inspection Triumph 5
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
S MGB mystery wiring plug MG 2
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
PAUL161 T-Series Odd spark plug encounter! MG 10
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
D Socket for TR3 Gear box drain plug Restoration & Tools 6
