TR4/4A Floats in TR4 ZS Carbs
Geo Hahn
I hope to take a look at the floats with the ZS carbs still in situ.
I can see I remove the 8 screws that hold the bowls but will I then be able to pull the bowl down & off or do I also need to remove the big brass plug (called the bush retaining screw, I would call it the jet carrier)? If the latter -- do the jet and other bits come out with it?
Perhaps whether I need to remove it will depend on how tight the o-ring is on the jet carrier?
thechileman
I have never removed the bowls with the carbs on the car, but I think you can undo the screws and the bowl will come off, without having to remove any of the other pieces. If I recall correctly, when I rebuilt mine, the bowls were the last part I screwed back on.
MDCanaday
This is dicey in the car,smart money is to remove them once, do them RIGHT, put them back.
Good luck with the O ring, it is poorly designed and hard to seal, sometimes the plug cracks.
MD(mad dog)
titanic
Removing the bowls with the carbs on the car is doable, but I would remove the air valve first to avoid bending the needle and also be careful not to bend the float. I don't believe there is a plastic plug on the adjustable jet assembly used on the TR4 ZS carbs. Berry
poolboy
You say you want to "take a look at the floats". You might also want to check the height and I don't see how that's going to be possible with any degree of accuracy unless the carbs are sitting upside down on the bench with the float chamber gasket removed.
Andy Blackley TR4/4A TR4 Stromberg Floats Triumph 2
R BT7 Carb floats Austin Healey 1
N Floats and needle valves Austin Healey 14
R GT6 Carb Floats for Stromberg 150 . Triumph 5
dklawson Early Stromberg Floats - 150CD Triumph 5
dklawson 150 CD Carb Floats - Early vs Late ? Triumph 2
jdubois Anybody tried these floats? Triumph 7
Marvin Gruber XKE Fuel floats Jaguar 7
Jim_Gruber Smell of gas, turns out not floats set too high Spridgets 4
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
K Sticking Floats Triumph 12
amcboy Mmmmm Carb Floats... And a request for opinions.. Triumph 10
T sticky floats? Austin Healey 30
middleagecrazy HS2 floats Spridgets 9
Michael Oritt Nitrophyle foam for floats Austin Healey 2
goloch Floats, AGAIN?!??!?!??! MG 2
goloch Well, the floats weren't stuck... MG 20
M Carburetor Floats Austin Healey 8
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
