As much as you have changed your engine mechanicals, an upgrade to your ignition system (possibly Pertronix components) is probably a wise choice for a next step.
Just keep in mind what Pertronix parts WILL and WILL NOT do.
1) The distributor drop-in Pertronix Ignitor Module is simply a magnetic on-off switch. A rotating magnet opens and closes this switch with a fair repeatability. The Ignitor module replaces the points, but only stabilizes your ignition "dwell". Dwell is the ratio of points open time vs. points closed time. Dwell affects your spark duration by varying the unit time your coil has to charge and discharge. With the module, dwell is preset and NOT adjustable as it is with points.
If you have a choice, choose the Ignitor module over the Ignitor II. Ignitor II modules have a trendency to let the dwell setting "drift".
2) To the attributes of the Ignitor module, the Pertronix Distributor adds very precise ignition timing and very precise ignition timing advance.
That is a double edged sword.
You have changed so many performance variables (head, cam, pistons), each one of which will GREATLY affect the ignition timing and advance curve that your engine needs, UNLESS you are willing to invest the time and effort necessary to map the fuel and ignition needs for your dramatically changed engine and to re-curve the Pertronix distributor to meet those needs, you would probably be better off just installing the module and leaving the distributor for another time.
Because of the timing and advance precision in the Pertronix distributor, unless the advance curve is correct, your engine might actually run more poorly than if you had left it alone.
If you have not done so, undoubtedly the best thing that you could do for your engine is to upgrade the coil. Your changing the head and pistons was undoubtedly for an increase in compression. Each point rise in compression (8.0 to 9.0, 9.0 to 10.0 etc) requires about a 10,000 volt increase in spark intensity across the same point gap to properly start the highly compressed fuel to burn.
Dropping in a high dollar distributor is not a performance "magic bullet". With a stock coil and improperly timed spark (precise, but ill timed), you could be worse off than before.
Tim
