Flamethrower Distributor Wiring
Bill_Reid
I am now in the process adding a new wiring harness (from British Wiring) to my '60 Sprite and have come to the distributor wiring. According to the instructions for the new distributor, I should attach the black/white wire from the distributor to the negative terminal of the coil. I have done this. The instructions then say to attach the black wire directly to the ignition switch wire. I am not sure what is meant by the ignition switch wire. The instructions then say to connect a 20 gauge copper stranded wire from the positive coil terminal to the positive battery or chassis. Is this necessary, given that the proper wire from the new wiring harness is already connected to the coil? Thoughts would be much appreciated.
Thanks...
smaceng
`The red wire is 12V ignition switched.....which should be connected to the + side of the coil. Normally, the + side is connected at the fuse terminal for switched 12V. This all assumes that you or someone else has switched the car to a negative ground. Black/white is connected as you have done it.
Scott in CA
Jim_Gruber
Bill,
Are you going to keep the car + Ground or - Ground. That will affect the way things get hooked up. One important precaution to prevent the smoke being let out of the new wiring harness is a inline fuse holder with perhaps a 5 Amp(someone else chime in here on the fuse Amperage Size) between the + Battery Terminal and the Lug on hte battery. That way if something is hooked up wrong, fuse blows instead of you letting the smoke out of hte wiring harness. Advice is to hook up wiring in a logical progression for subsytems i.e. lights, horn, turn signals, etc. and test along the way rather than the "big bang".
Pythias
If you still have a Positive Ground,, AND the Flamethrower is wired the same as a Pertronix module. you do indeed have to run a wire from the positive terminal of the coil to the ground of the car. Won't run otherwise. Follow the instructions.
F TR2/3/3A Flamethrower Distributor Triumph 18
B Petronix Flamethrower Dist. Austin Healey 20
D Flamethrower coil install Triumph 4
M FlameThrower vs PertronixElectronic Ignition 100-4 Austin Healey 9
19_again flamethrower coil on positive ground B MG 4
RickB Pertronix Ignitor & Flamethrower kit? Opinions? Spridgets 19
jhorton3 Flamethrower Installation Spridgets 4
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
M Accuspark distributor Spridgets 2
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
vette Distributor Advance Austin Healey 14
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
M TR2/3/3A 25D4 CSI Optimized Distributor Triumph 4
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
R Distributor: Reassembling BJ8 Engine Austin Healey 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
P DM6A Distributor Question Austin Healey 9
A TR2/3/3A A123 distributor Triumph 5
AUSMHLY Distributor cap center pin melted Austin Healey 5
M Mallory Dual point distributor Austin Healey 0
K TR2/3/3A Distributor Caps Triumph 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
K TR2/3/3A The Distributor Dwell reading... Triumph 1
W Mallory distributor on '60 BT-7 Austin Healey 4
R TR2/3/3A Establishing distributor shaft end float Triumph 4
