Fan Hub Clearance Over Steering Rack?
RJS
How much clearance is considered correct? My fan hub doesn't rub on the steering rack but, boy is it close. I can't even fit a credit card between the two.
I understand I can fix improve the clearance by slipping a few diff washers under the front motor mounts. Is this worthwhile or am I worried about nothing?
Bob
TR4nut
Bob-
Normally I think you'd have a half inch or more gap - the main headache is if you break a fan belt it will be difficult to make any roadside fix.
Randy
Geo Hahn
Mine is close to... but not too close. Maybe 3/8". A credit card clearance would worry me.
As noted, the main issue is fan belt installation. I have to loosen the motor mounts and jack up the engine a bit. The TR3 trick of cocking the wheels to one side to increase the clearance doesn't get it done on a TR4.
I carry a length of rope in case I need to make a temporary belt to get home (have had to once).
Once saw a guy who had fitted a second belt thru there and then zip-tied it out of the way to be ready to go when needed. A real plan-ahead sort.
KVH
My clearance in my 4A was about 1/4" at best, so, following advice on this amazing forum, I bought some large, thick washers, cut slots in them with a dremmel tool, loosened the engine mounts, raised the engine, and slid the washers down over the bolts.
One of the folks here posted pics of the same procedure.
RJS
RJS
Thanks,
Sounds like I should raise it a bit. I had to do the whole unbolt engine mounts, and raise engine when I replaced my fan belt last year. So, I know it's not a big job. I have a couple of extra diff washers (3/16" thick) which are perfect size. I try slipping one in each side to see how much I gain and possibly consider two on each side if needed.
Not too worried about the belt replacement issue as much as I am the hub rubbing on the rack and causing larger issues.
Cheers,
Bob
PS: my motor mounts are only a couple of years old. HD set from BPNW so I know the issue is not old/collapsed mounts.
PPS: those new HD motor mounts made a HUGE improvement in the over all feel of the car. Much less vibration transmitted into the car over my 42 year old mounts.
GTP1960 TR2/3/3A Removing the fan extension from the Crank hub Triumph 13
Willie_P TR4/4A Fan Hub Extension removal early tr4 HELP Triumph 9
T Hub and pulley and fan alignment question Triumph 19
Bremer TR2/3/3A TR3/4 fan hub extension elimination kit? Triumph 3
TRclassic3 TR2/3/3A TR3 fan pulley hub Triumph 3
mountainman TR2/3/3A Tr3 Fan Hub Triumph 1
J TR4/4A TR4 Fan Hub Extension replacement Triumph 4
E TR4/4A TR4 Fan Hub Triumph 4
Tinkerman TR2/3/3A Fan to Fan Hub Extension Torque Data TR-3 Triumph 5
T TR4/4A TR4 Engine - Fan Hub Extension Triumph 4
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
F Revotec Fan Austin Healey 2
S Installing a Radiator Fan Austin Healey 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
RJS TR4/4A Radiator Fan Shround Triumph 3
KVH General Tech Fan Not Backward — Balancers Triumph 5
A Spitfire Install fan Triumph 1
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
R six bladed fan - bugeye Spridgets 2
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
Lin Fan belt for 1275 with alternator Spridgets 4
Tr3aguy TR2/3/3A Tropical Fan Triumph 19
G Thermo Fan Sensor Austin Healey 5
R TR6 fan shroud replacement Triumph 5
J BJ8 Radiator Fan Austin Healey 12
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
D Spitfire Electric fan Triumph 3
Zitch For Sale 8 Blade yellow Fan for triumph Triumph Classifieds 2
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
T BJ8 Fan Belt Change Austin Healey 7
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
S Heater and fan control replacement - any advice? Austin Healey 9
B Fan Blade Failure Austin Healey 6
D Fan Blade Austin Healey 11
B Revotec fan kit Austin Healey 4
B TR6 TR6 Fan Belt Triumph 4
