Edit--gloss level for the steering column and hub?
Tr4dude
Getting ready to powdercoat the steering column and hub on the Tr6 and was wondering what gloss level of black most of you went with? Is the hub made out of aluminum or pot metal? Thank!
DougF
Re: Colors for the steering column and hub?
Mine is currently a very scratched and rubbed black.
Tr4dude
Tr4dude
Doh!! :wall: I should have been more specific, what gloss level is factory and what level of gloss did you coat yours with??
dudley32 How to change or edit title on a thread FORUM Navigation Questions 2
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
Tabcon Can I edit my original topic? Triumph 3
bcliff Need to edit the fleet list British Motor Corp 0
tr3guy TR2/3/3A Miscellaneous bracket and component paint -- gloss or semi-gloss Triumph 5
Got_All_4 TR2/3/3A Gloss black or satin black paint Triumph 17
K gloss paint bj8 under hood Austin Healey 9
T MGC MGC air intake box supposed to be gloss black? MG 12
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
E General MG Transmission Fluid Level MG 2
AngliaGT Saw These in Rocky Mount & Oak Level,VA Spotted 1
Basil Neat trick for reading oil level Restoration & Tools 7
Jim_Stevens TR2/3/3A Door fitting- graduate level Triumph 25
K TR2/3/3A Radiator coolant level? Triumph 5
R Gearbox and Overdrive Oil Level Austin Healey 18
AUSMHLY Lever Shock Oil Level Austin Healey 41
HealeyRick Gold Level Concours Value Austin Healey 20
S BJ8 Float Level Austin Healey 37
K TR2/3/3A Correct oil level for differential? Triumph 5
I Bugeye dash pot oil level Spridgets 3
K TR4/4A Mechanical fuel pump glass bowl level? Triumph 1
R MGB-GT Just purchased Tuned for sea level, but I live at 7500', running rich MG 7
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
T TR4/4A adjust fuel level Triumph 8
F Exhaust gas analyser - what carbon monoxide level should I expect from my BT7? Austin Healey 7
gbtr6 TR6 TR6 Oil Level, New Motor and Leak Triumph 16
P Coolant level indicator wrong? Jaguar 4
T TR2/3/3A SU H6 float level Triumph 4
sundown TR6 OIl level issue Triumph 0
RJS TR4/4A Lever Shock Fluid Level Triumph 1
R Od fluid level Austin Healey 4
P BJ8 SU carb float level Austin Healey 6
E With frame on level stands my drivers front fender is 1 inch higher than the pass? Austin Healey 5
K TR2/3/3A TR3 dipstick marks and oil level? Triumph 5
A Wedge SU on TR7 Float Level Engine Angle Triumph 10
doates Spitfire Why Doesn't My Spit Sit Level Triumph 8
glemon SU Carb question float level/leaner/richer Austin Healey 2
Jeepster Shock absorbers oil level. Austin Healey 6
Go_Dogs_Go Getting level Spridgets 12
Nelson SU float level changes Spridgets 8
S Float Level for HD8, BJ8 carbs Austin Healey 9
Hornzackwamme Borg Warner 65 fluid level Restoration & Tools 1
pjsmetana Fuel Level Sender needed... Triumph 5
wangdango stroberg fluid level? Triumph 4
bluemiata90 Wedge TR8 COOLANT LEVEL SENSOR LOCATION Triumph 4
Nelson Setting float level Spridgets 9
jvandyke HS2 float level Spridgets 10
Tinkerman TR2/3/3A Petrol Level Sensing Unit Ground Wire TR3A Triumph 3
