TR2/3/3A Door Striker Issue
DornTRoriginal
I am in the process of checking on the mounting of the tub to the frame and I noticed that one of the screws on the striker plate is striped, how do I fix this?
charleyf
I believe that all four screws fit into a single plate with the four holes. One method is to find a slightly larger screw and tap a new set of threads. Finding a screw for this will be the big job but the original is a 1/4" so maybe even a metric could work.
bobhustead
The plate is removable by lifting an edge of its capsule, after which it can be duplicated or repaired. They also make screws with #6 heads and #8 threads. The hardware bin at some Ace or TruValue will have them.
CJD
This! You have to go in through the hole behind, which is normally covered by the quarter trim panel. You have to pry the tab back on the retaining plate to access the nut plate. The chromed screws are available from the big three.
sp53
try and re- tape it with the correct tape ( it is standard thread) and see if you can a little bit of threads back. You have 4 on that little thing and one being a little weak will be fine and you might get all the threads back and it will be strong. If that does not do it and you cannot live with 3, I would go John’s way.
Got_All_4
if you have access to the back and the screw goes all the way through. Thread a nut on the back and tack weld it to the plate. clean up the metal first before trying to weld it.
Rut Bugeye door striker Spridgets 14
B TR6 Correct finish for door striker plate Triumph 2
RandallRK Door latch striker nut sourcing- 100-4 Austin Healey 3
K Spitfire Door striker 63 Spit Triumph 1
bighealeysource installing door striker Austin Healey 1
livinginthepast Bugeye door latch and striker help Spridgets 10
M Door striker question. Spridgets 1
John Loftus Door striker plate dimensions needed Austin Healey 8
F Door striker plate Triumph 3
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
