Bugeye door striker
Rut
I've started adjusting the doors on my Bugeye and realized I'm missing one of the door strikers. I really want to use the originals vs a reproduction and wondered if anyone has one they are willing to part with.
Thanks, Rut
Jim_Gruber
NOS Locators? They had some a while back.
Rut
Rut
Jim,
Thanks, but even though they say it fits better than the Moss striker I would rather have an original. Now the good news...I found a pair on eBay that I missed before!
Rut
Usually, used ones are pretty worn out. If you can not find NOS, then you might be better with new.
markberry
Usually, used ones are pretty worn out. If you can not find NOS, then you might be better with new.[/QUOTE
what would one look for in terms of wear? The whole door latch assembly seems pretty straightforward. Mine won't latch closed without me pulling the knob down before closing the door all the way however...is that a worn condition?
mark
The hole gets worn to an oblong shape and the door starts popping open.
Rut
Rut
Trevor,
The ones from Moss are too big to allow it to fully lock, so I bought a pair on eBay in hopes that one would be good. I have no experience with the ones from NOS Locators, but will give them a try if the used ones are too loose.
Thanks, Rut
histerical
You can look at the bottom of the strike and see wear from the latch. You may also just need to take the latch out and check to see that it's working smoothly . Or maybe just lube it. If it's bee stiff for years, it probably wore out the strike. Somehow, I'd think that a really worn strike would not latch very well in any case.
I have a used one in very good shape( probably passenger side) if you want it.
Bill
Rut
Rut
OEM door striker in great shape coming your way tomorrow.
Ray,
To the rescue once again! I can't thank you enough for all you've done for me over the years!
Thanks, Rut
Whitephrog
Lied slightly. Life and a sticky screw got in the way of my good intentions. Striker will go out tomorrow.
smaceng
When I put 60Frog together, I remember the new strikers not formed correctly. I ended up re-newing the old ones.
Scott in CA
Rut
Rut
Thanks guys! Ray, no hurry since I still have a lot of things I'm doing to finish up. I will post a couple of updated pictures of my progress on a new topic.
Thanks, Rut
Rut
Rut
Ray,
The door striker arrived yesterday afternoon along with a spacer (I've never seen that) and 2 screws. Thanks so much for a striker that fits well!
Rut
livinginthepast Bugeye door latch and striker help Spridgets 10
B Which is the correct door knob for a 59 bugeye? Spridgets 3
Rut Bugeye door panel glue Spridgets 13
DanLewis Bugeye Door Latch - How to keep it from flopping around? Spridgets 20
L Bugeye door pocket metal trim Spridgets 0
I Bugeye door latch question Spridgets 4
I Source for ribbed material for inside bugeye door? Spridgets 5
I Help with Bugeye door seals Spridgets 7
I Bugeye door seal help please Spridgets 8
I Bugeye door gaps/fit Spridgets 13
I Bugeye door allignment help please Spridgets 9
P BUGEYE DOOR POCKETS Spridgets 2
W Bugeye Door Pockets Spridgets 2
histerical Bugeye door panels Spridgets 7
John Moore LH Bugeye Door Spridgets 5
TexasSprite Door liner idea for Bugeye Spridgets 5
W Bugeye Door Latches Spridgets 1
B Looking for a BE [BugEye] drivers door? Anyone? Spridgets 20
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
