Door Adjustment on a BN1
TonyR
The rear of the driver's door is sticking out by about 3/16" and looks unsightly.
How do I re-align the door to it's correct position?
roscoe
Are you sure it is a hinge alignment issue. It can also be the door latch. The latch post is adjustable by moving the plate it is attached to, at least on my BN2. Adjusting the hinges is a trial and error process. I find it is mostly error and trial with success only after hours of fidgeting. This is because you have to back-off the hinge screws in either the door pillar or on the door side, tap the door with a mallet to get it to move a bit, snug the screws and try the door. It took me so long at the end of my rebuild that now that they are a bit out after 5K miles, I find it doesn't bother me as much as it used to.....
T
TonyR
Yes, I believe it's the door latch that needs adjusting.
I have slackened the latch post on the B pillar but find it has limited travel.
Can the latch in the door be adjusted?
Keith_M
If the door latching mechanism is the same on a BN1 as a BT7, then I don't believe you can adjust the door latch itself. However, the post on the B pillar should have enough travel to get the door lined up. You might try removing the post completely and seeing what is limiting the travel.
Also, are you sure the door is closing all the way. The door latch should stick into the hole on the post (not just catch the ridge).
roscoe
I enlarged the holes in the rear door pillar so that the plate holding the latch post could be moved more than what is normally the range. Some may say that's cheating, but you can't seen it and I prefer to think there are no rules for stuff like this. I do what works.
pan
"I do what works."
So did Jensen when they built them in the first place.
Keith_M
Awesome! It's always nice to hear back that things got solved in the end.
LAW75 Door Latch Adjustment Austin Healey 22
C Door adjustment after installation of new door panel? Austin Healey 9
I TR6 Door adjustment Triumph 2
bighealeysource The dreaded door adjustment Austin Healey 11
HealeyDave Door Check Friction Adjustment Austin Healey 12
C TR6 Door window adjustment Triumph 2
bighealeysource door latch adjustment on BN2 Austin Healey 5
M Door Handle Adjustment Triumph 2
bighealeysource Door adjustment on BN6 Austin Healey 7
M Adjustment of XJ6 Door Locks with Keikert Solenoid Jaguar 5
bighealeysource DOOR ADJUSTMENT ON BJ8 Austin Healey 12
TimK BN7 door latch adjustment Austin Healey 11
bcbennett TR6 TR6 Door adjustment...possible? Triumph 1
Woodie drivers door adjustment Spridgets 4
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
