Hello LBC Folks.
I hope that springtime is heading your way.
I have a question re. adjusting the handle on a TR3A door. The handle is no longer horizontal, but returns to "above horizontal." I had assumed that it is a "spline-type" adjustment, i.e., pull the handle off the spline move it a couple of notches, and push it back onto the spline. But this is not the case, I am told.
The adjustment lies in the cord? If the handle is coming back too far after opening the door, I need to shorten the cord? Lengthen the cord? I installed new door pockets on both doors, so this might be causing my problem. The passenger door is OK, but it is just a matter of time...
I look forward to hearing from you.
Thanks,
Phil
Thanks,
Phil
