drivers door adjustment
Woodie
A question about the door. The car has new sills installed a couple of yrs ago by the PO. The top of the driver door just rubs the B post when closing. There is maybe 1/8 - 3/16 inch at the door and A post. Is there any adjustment inside the door at the upper hinge to eliminate this rubbing??
jlaird
Yep yep. door hinges.
Screws to A post move door up and down and in and out.
Screws to door move door back and forth.
Woodie
Woodie
Thanks Jack,,, You have given me stuff to do tonight or tomorrow night.
Nose
Member
was looking for help with my driver side door not closing. this is an old post, but it helped my situation greatly. hope you are still around. God bless.
Jim_Gruber
Try removing the latch. Get door aligned with proper gaps and not rubbing anywhere. PS was easy peasy, DS is a bitch, I have top hinge in to far and bottom hinge out to far. Reversing that order is on my list to do. Once gaps are good reinstall the door latch. Latch has a bit of adjustment possible as well. And then I will go back and fix the paint.
F XKE SIII Drivers Door Mirror Knob Jaguar 1
Marvin Gruber T-Series TD or TF drivers door handle needed MG 9
M 1985 XJ6 Drivers door lock Jaguar 5
B Looking for a BE [BugEye] drivers door? Anyone? Spridgets 20
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
HealeyRick Healey Drivers at F1 Montreal Austin Healey 2
DornTRoriginal TR2/3/3A Tub gap between Frame Drivers side Triumph 3
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
HealeyRick What Healey Drivers Look Like Austin Healey 21
K TR4/4A Any daily drivers? Triumph 8
CJD General Tech The Story of New Drivers Triumph 12
T 100S Drivers Handbook Austin Healey 8
charleyf TR6 Plate on drivers side front inner fender Triumph 6
K MG Midget rear drivers side spring sag? Spridgets 7
maxwedge5281 drivers side 4 inch vent hose Austin Healey 5
DNK Wedge Traggic Day for 2 Holland Drivers Triumph 11
E With frame on level stands my drivers front fender is 1 inch higher than the pass? Austin Healey 5
T Question on removing drivers front lower wishbone Triumph 7
aeronca65t MG Drivers MG 0
Patrick67BJ8 Drivers Floorplan Dimensions needed Austin Healey 13
dougie The Drivers - TV Series Racing 1
R BE Drivers Seat Spridgets 2
af3683 TR2/3/3A TR3 Drivers Side Defroster Vent Triumph 11
jlaird Drivers Handbooks Spridgets 11
M Drivers seat setback Austin Healey 2
Marvin Gruber Drivers side vent glass BJ8 Austin Healey 2
jlaird Put the drivers seat Spridgets 4
PeterK Central Maine Triumph drivers Triumph 28
IanF Spitfire Clutch question for Spit drivers... Triumph 13
V Older Triumph Drivers may remember the days Triumph 19
davidk Drivers seat is too wide! Triumph 4
B Up-dated Pics! completely restored the drivers seat Spridgets 16
S White disk in drivers seat 1979 Midget? Spridgets 3
jlaird Impact drivers, and proper use of same Spridgets 8
3 Found a car, any cross country drivers out there? Triumph 2
PAUL161 MGB 1972 MGB Owners Manual / Drivers Handbook MG 2
JPSmit Drivers side fender removal Spridgets 1
mgbmedic drivers seat does not recline MG 4
KLUTZ Wedge Question for all TR7 drivers Triumph 9
B What do Healey drivers do when the cars are finished? Austin Healey 5
D Early Elans as daily drivers? Lotus 21
CDK Conclave Drivers Austin Healey 3
huck6 Mini for Tall Drivers? British Motor Corp 8
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 6
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
