drivers side 4 inch vent hose
maxwedge5281
there is a large metal hoop...not clamp...that helps to support the drivers side vent hose. can anyone tell me where this supporting hoop is located on the hose and is there a predilled hole for it to mount on the inner fender? thanks for any help!
Keoke
Yes it is located where you find that pre-drilled hole on the inner fender-- look for it.
maxwedge5281
maxwedge5281
keoke, that is part of the problem, i have several holes . i think that i have found the correct one. i was too far forward on the inner fender. i found a hole that seemed to locate the tubing bracket correctly to the rear side of the shroud support. thank you.
Keoke
Yea that sounds about right you did a better job of describing it's location than i would have
Healey Nut
Does this help
maxwedge5281
maxwedge5281
thank you. unless the bracket is for a different model, i have it on the wrong side of the shroud support. thank you.
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
DornTRoriginal TR2/3/3A Tub gap between Frame Drivers side Triumph 3
charleyf TR6 Plate on drivers side front inner fender Triumph 6
K MG Midget rear drivers side spring sag? Spridgets 7
af3683 TR2/3/3A TR3 Drivers Side Defroster Vent Triumph 11
Marvin Gruber Drivers side vent glass BJ8 Austin Healey 2
JPSmit Drivers side fender removal Spridgets 1
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
HealeyRick Healey Drivers at F1 Montreal Austin Healey 2
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
HealeyRick What Healey Drivers Look Like Austin Healey 21
K TR4/4A Any daily drivers? Triumph 8
CJD General Tech The Story of New Drivers Triumph 12
T 100S Drivers Handbook Austin Healey 8
F XKE SIII Drivers Door Mirror Knob Jaguar 1
DNK Wedge Traggic Day for 2 Holland Drivers Triumph 11
E With frame on level stands my drivers front fender is 1 inch higher than the pass? Austin Healey 5
T Question on removing drivers front lower wishbone Triumph 7
aeronca65t MG Drivers MG 0
Marvin Gruber T-Series TD or TF drivers door handle needed MG 9
Patrick67BJ8 Drivers Floorplan Dimensions needed Austin Healey 13
dougie The Drivers - TV Series Racing 1
R BE Drivers Seat Spridgets 2
jlaird Drivers Handbooks Spridgets 11
M Drivers seat setback Austin Healey 2
M 1985 XJ6 Drivers door lock Jaguar 5
jlaird Put the drivers seat Spridgets 4
PeterK Central Maine Triumph drivers Triumph 28
IanF Spitfire Clutch question for Spit drivers... Triumph 13
V Older Triumph Drivers may remember the days Triumph 19
davidk Drivers seat is too wide! Triumph 4
B Up-dated Pics! completely restored the drivers seat Spridgets 16
Woodie drivers door adjustment Spridgets 4
S White disk in drivers seat 1979 Midget? Spridgets 3
jlaird Impact drivers, and proper use of same Spridgets 8
B Looking for a BE [BugEye] drivers door? Anyone? Spridgets 20
3 Found a car, any cross country drivers out there? Triumph 2
PAUL161 MGB 1972 MGB Owners Manual / Drivers Handbook MG 2
mgbmedic drivers seat does not recline MG 4
KLUTZ Wedge Question for all TR7 drivers Triumph 9
B What do Healey drivers do when the cars are finished? Austin Healey 5
D Early Elans as daily drivers? Lotus 21
CDK Conclave Drivers Austin Healey 3
huck6 Mini for Tall Drivers? British Motor Corp 8
K TR2/3/3A Side view mirrors again Triumph 8
roscoe Side Curtain Hardware Austin Healey 2
G Right-Side Shock Weeping Oil Austin Healey 1
