doughairfield
The rear differential on my TR4 is slowly leaking lubricant due to the puddle accumulating in my car port. I'm pretty sure it's not where the drive shaft goes into the diff. Is it as simple as draining the fluid and replacing the gasket, then putting cover back on and and torquing to the appropriate value? Or is there something more once I get that cover off that I would have to do?
