Diff Drain Plug
ScottTR6
Hi, I've got a 1960 Sprite, and decided it was time to drain & change the Diff fluid myself, always paid before. What tool do you use to remove the drain plug? It appears to be between 3/8 & 1/2 inch, square hole? Didn't want to strip the inside with my 3/8 drive, very loose fit. Thanks, Andrew
It is exactly that - I have managed to get mine with my 3/8 drive socket (so far) most of everyone grinds down a 1/2 inch breaker bar or old socket drive to make it fit.
Just do an old 1/2" extension.
That way you don't have to deal with killing a breaker bar or ratDoody nor deal with the button release on some.
Paint said extension white or red so it is easily identifiable in your toolbox, and you don't try to use it for regular sockets.
Dave
Thanks all, I've got an older 1/2" extension just ready to be sacrificed!!
I had a piece of 7/16" square stock welded into a 1/2" (I think) 12 point socket, then used a grinder to bull nose the end. .. perfect fit. NO tool maker (Snap-on, Mac, Proto, etc, etc, etc makes the right tool anymore. You have to do it yourself.
Miss Agatha says a 3/8 rachet and estension fits just right. LOL
It's a NPT pipe plug, so yo u can always get one at the hardware/fastner store with allen head in it, thats what I do on the race cars. For the stock ones, I ground down a 1/2" cheap extension.
Lesson learned last fall. Drained the BE differential, then spent 2 hours getting the fill plug out. Now I do the fill plug first, THEN drain the fluid...I ground down an old bolt to fit the drain plug and put a socket to it.
drooartz Question: diff drain plug Spridgets 5
TonyPanchot TR5/TR250 250 Diff drain plug ? Triumph 15
V Diff drain plug sealant? Spridgets 5
B TR6 TR6 Diff. Drain Plug Question Triumph 5
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
Darwin GT6 Diff Help Please Triumph 2
skystryd Trans and Diff Spridgets 7
M TR4/4A Diff comparisons Triumph 2
N TR6 Triumph Diff which model??? Triumph 1
pbraun Wanted 3.9 diff for sprite Spridgets Classified 5
steve00136 MGB Diff refurbish MG 6
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M TR4/4A Diff Conversion Triumph 3
T Diff Ratio BJ7 Austin Healey 5
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
K TR2/3/3A 3.45 Diff ratio? Triumph 7
B best diff British Motor Corp 5
wangdango '67 XKE rear diff? Jaguar 2
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
B diff ratio British Motor Corp 3
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
69MGC MGC Diff Oil MG 1
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
drooartz Diff pinion nut Spridgets 10
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
R TR2/3/3A Lockheed diff setup Triumph 6
Boink 3.9 diff and pinion seal Spridgets 2
Boink 5 speed vs. 3.9 diff - either or both? Spridgets 165
Michael Oritt 3.54 diff for sale Austin Healey 1
drooartz Diff pinion seal Spridgets 8
Rut Diff plug tool Spridgets 7
Geo Hahn General TR Diff Pinion Seal Triumph 5
Geo Hahn TR2/3/3A Paint Dab on Diff Cover Triumph 6
A TR4/4A Changing rear diff seals Triumph 15
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
JFS Wedge Diff Cover Gasket Adhesive Triumph 10
G Diff and trans oil Spridgets 8
C TR4/4A Diff gear wear Triumph 10
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
K TR2/3/3A 4:1 Diff in a TR3? Triumph 3
steveg Limited Slip GM Healey Diff Austin Healey 4
DerekJ 11:39 Diff for sale. Austin Healey 0
H Noisy diff in BJ7 Austin Healey 2
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
