Denis Welch Steering Box
stretchit2
Fellas
Has anyone installed a Denis Welch Steering Box?
If so, what are your thoughts about the pros and cons of the product?
Was it a standard ratio or a high ratio?
Any thoughts or comments would be appreciated.
Cheers Jeff
John Turney
Denis Welch makes first-class stuff. I have several of his items, but not the steering box. I had to rebuild mine because of pitted bearing surfaces before he came out with his. I do have the high ratio box because I have an early BN4. I can tell you that it's fine at speed and gives the steering a great response. The trade-off is really heavy steering at parking speeds, especially with195-width tires. Unless yours is really trashed, I would seriously consider rebuilding and properly adjusting the one you have, rather than spending close to $2,000 for a new one (unless you race your Healey).
Hoghead
I too am interested in this as my steering leaves a lot to be desired
Also looking at rack and pinion conversion kits
JBN2100
I have a BN2 that I took through a restoration. The car had a BN1 steering box in it that was in pretty bad shape, and I wanted to upgrade. I first purchased an SC unit (on sale -- the later style) and went through the installation, only to find that the splines for the steering wheel were not machined correctly. I ended up removing the SC unit and sending it back. I then purchased the DWR unit. Great quality all around. Installation went smoothly -- everything fit like factory and the unit is great on the road. The DWR unit is clearly the way to go and worth every penny.
stretchit2
stretchit2
JBN2100
Thanks for the input. I ordered one yesterday, and the Brits apparently have forgiven us for the whole Independence thing, as DWR shipped it on the 4th of July.
Cheers,
Jeff :cheers:
WHT Denis Welch CENG635SO Flywheel Austin Healey 0
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
Fortius For Sale AH 3000 MK III Phase II 1967 - Denis Welch Engine & Parts Austin Healey Classifieds 0
steveg Denis Welch mild cam Austin Healey 9
H Denis Welch cooling fan arrived today Austin Healey 2
V Denis Welch Austin Healey 5
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
J Denis Welch STEEL ROCKER PEDESTALS AND SPACERS Austin Healey 1
Roger Denis Welch RIP Austin Healey 12
Patrick67BJ8 Denis Welch Air Filter for BJ8 Austin Healey 22
M Denis Welch Vernier Cam Sprocket Austin Healey 8
Randy Forbes Denis Welch 100/S brochure... Austin Healey 0
A Denis Welch Aluminum Head on a 100M Austin Healey 9
6 Denis Welch Brake Drums? Austin Healey 5
E Denis Welch Dual Circuit Brakes [BN2]????? Austin Healey 9
R Denis Welch Header Austin Healey 2
B Welch air filters Austin Healey 5
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
H Dennis Welch Cooling Fan Austin Healey 9
Frankenhealey Welch Endurance Car for sale Austin Healey 2
zschicago Installed Dennis Welch brake kit Austin Healey 5
HealeyPassion Impressive video Jeremy Welch racing in rain Austin Healey 7
6 Question re: Welch Brass Radiator Austin Healey 5
Fortius Dennis Welch Rear Disc Brake Conversion Kit Austin Healey 2
DerekJ Dennis Welch Headers - their view Austin Healey 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
