Denis Welch Header
rc157
A little help: if the header is 2 in and I want to use that stainless cpl from jcw, what size do I need? This is becomming a real problem trying to match it up to an Abarth system for a BJ8. Any help is appreciated
Dave Russell
Yoda - R.I.P
Hi RC,
The JCW flex pipes appear to be sized by ID. For example, a 2" ID coupler would fit over a 2" OD pipe & could be clamped or welded. The 2" appears to be available in 8, 10, 12, & 14" overall lengths. You need to verify the diameters of the pipes you plan to connect together. The couplers come in various diameters.
https://www.jcwhitney.com/autoparts/Produ...=exhaust%20flex
If your header is two out & the muffler is two in, you would need two couplers. You could shorten the header extensions to make room for the couplers.
dave russell,great info on the stainless j.c.w. stuff,just found a leak in mine will have to be replacing.seem to be resonably priced as well. /ubbthreads/images/graemlins/yesnod.gif
WHT Denis Welch CENG635SO Flywheel Austin Healey 0
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
Fortius For Sale AH 3000 MK III Phase II 1967 - Denis Welch Engine & Parts Austin Healey Classifieds 0
steveg Denis Welch mild cam Austin Healey 9
H Denis Welch cooling fan arrived today Austin Healey 2
V Denis Welch Austin Healey 5
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
J Denis Welch STEEL ROCKER PEDESTALS AND SPACERS Austin Healey 1
Roger Denis Welch RIP Austin Healey 12
Patrick67BJ8 Denis Welch Air Filter for BJ8 Austin Healey 22
M Denis Welch Vernier Cam Sprocket Austin Healey 8
stretchit2 Denis Welch Steering Box Austin Healey 4
Randy Forbes Denis Welch 100/S brochure... Austin Healey 0
A Denis Welch Aluminum Head on a 100M Austin Healey 9
6 Denis Welch Brake Drums? Austin Healey 5
E Denis Welch Dual Circuit Brakes [BN2]????? Austin Healey 9
B Welch air filters Austin Healey 5
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
H Dennis Welch Cooling Fan Austin Healey 9
Frankenhealey Welch Endurance Car for sale Austin Healey 2
zschicago Installed Dennis Welch brake kit Austin Healey 5
HealeyPassion Impressive video Jeremy Welch racing in rain Austin Healey 7
6 Question re: Welch Brass Radiator Austin Healey 5
Fortius Dennis Welch Rear Disc Brake Conversion Kit Austin Healey 2
DerekJ Dennis Welch Headers - their view Austin Healey 7
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Intake header crossover passage..... Triumph 4
CARSINC Please Identify this Exhaust Header Spridgets 2
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
JFS TR2/3/3A Exhaust Header Fitment Triumph 13
P For Sale Weber carb/intake, header Spridgets Classified 2
J For Sale Header, hub caps Spridgets Classified 1
M Muffler Options with Exhaust Header Spridgets 1
bugedd Free header Spridgets 0
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
Rut TR4/4A Header seal attachment Triumph 0
Rut TR4/4A Header seal Triumph 3
R TR6 tr-6 header Triumph 0
B Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top Austin Healey 9
D TR4/4A General header question Triumph 6
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
Joe Reed General Tech VHT Flame Proof Header Paint MG 17
tomshobby Header Rail Seal Spridgets 4
H TR4/4A Header Rail Assembly Triumph 2
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
Jim_Gruber Looking for header and rear BE Top bars Spridgets 18
N Recommend a header? Spridgets 4
D BJ7-8 header seal retainer Austin Healey 3
