Dcoe????
nomad
I'm hoping there are still some Weber DCOE GuRu's on here.:rolleye:
Anyway, I want to lean my idle jet slightly. Currently a 50-F8. Should I drop the orifice size [50] or the air correction [F8]? Does it matter?
Trying to get better cruise mileage.
Kurt
Deleted member 8987
Not a guru.....used to work with Webers.....but then we were only interested in how much we could get through them and what it did for acceleration an top end.
http://www.redlineweber.com/html/Tech/dcoe_adjustment_layout_typical_i.htm
I haven't seen a need in days gone by to re-jet idle circuit from factory, as we could adjust idle mixture for each bore AND air bypass.
The amount of mileage change at highway speeds from a slightly rich idle circuit would seemingly be negligible.
How does the pipe smell running warm at idle? Plugs getting black with extended idle?
Just interested.
N
nomad
TOC, I haven't done an extended test at idle. Color Tune indicates that it is maybe just a tad rich. I't is my understanding that the idle adjustment screws and the idle jet are what you are mostly using at cruise. I dropped the main from 140 to 135 and it was obviously too lean so my next move would be to tr. y and lean the idle jet a bit. Only getting 25+ MPG while my other Spridget with virtually the same engine but a single HS6 gets low to mid 30's at freeway speed's. With a 7 gallon tank I don't get far between fills. As a friend like's to say about his DCOE carbed Jensen Healey, it will pass everything but a gas station!
Kurt
Deleted member 8987
Weird. Yes, I know excessively rich idle mixture works into cruise. But I am trying to remember...too many carbs, mostly downdraught...principles are similar.
Off idle, transition circuit, power circuit, cruise circuit.
Slightly rich, can't recall that affecting cruise mileage, but who knows.
RAM is full.
Need to reboot.
Deleted member 8987
"The correct interworking of all circuits together is the ultimate goal of a properly tuned DCOE. However, one must be careful as the circuits overlap one another; it is possible to sometimes fix an over-fuel situation in one circuit by under-fuelling in another. "
Weber calls "transition circuit" "progression"
"The Idle Jet is inappropriately named as it primarily controls the cruise mixture more so than the idle mixture. In fact, the Idle Enrichment Screw directly controls the idle mixture. The Idle Jet simply feeds it.
When cruising along a street or highway in a Datsun, the Progression Circuit is the main contributor to the mixture entering the engine. Only the fuel level and Idle Jet are at play. It is very important to select the correct Idle Jet and set the correct fuel level in a DCOE carb so that a suitable air/fuel ratio at cruise is obtained. In the tuning section below, selecting the correct Idle Jet at cruise will be the first and most crucial step. The mixture at cruise can not be tuned by the main circuit nor can it be significantly tuned by the Idle Enrichment Screw. The cruise mixture must be set by selecting the correct Idle Jet AND by setting the correct fuel level. "
So, it does. Now you need data, so you know how rich it is, try another set of jets, and check again.
You are not in the "main circuit" at cruise, rather the "progression" or "transition" circuit.
All the settings are done from know good and correct fuel level settings.
N
nomad
TOC, I thank you for that. Since fitting a DCOE I have had to take a crash course in how these things work and I have seen that site. Neverless I appreciate that.
I'm thinking maybe a call to Redline or Pegasus might be in order or just taking a chance on my next move. Folks with DCOE's DO end up with extra jets and other bits. Like a fool I let a coffee can full of Weber bits go with a car a while back.
Deleted member 8987
All those years of messing with Webers...and Mikunis...and Quadraflushes, Thermotoilets...
Zenith, Stromberg, SU's.....even Ford Variable Venturis...and guess who got to work on THOSE in shops?
Like a downdraught Stromberg...crossed with an SU.....and here I am, running 2bbl downdraughts on my Fatheads, and twi single bbl downdraught Solexes on the jag.
Good thing I avoided Hilborn Injection.
N
nomad
Pegasus site makes it look as if dropping the F number by 2 might be worth a try. The warnings were right....I'm wracking up a expensive collection of jet's.
SD Bugeye
Get on eBay some times you can pickup a used collection there on the cheap
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
N Dcoe????? Spridgets 1
PeterK TR4/4A DCOE air filters Triumph 5
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
sim air filter box for a DCOE 40 Spridgets 3
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Jetting a 40 DCOE for 1275 Spridgets 18
T Identifying vintage of a Weber DCOE Spridgets 4
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
sim High performance DCOE carbs 40 or 45 Spridgets 5
N DCOE double vs. single choke theory Spridgets 11
hondo402000 Weber Carburator rebuilding DCOE Triumph 14
bugedd Weber DCOE question Spridgets 43
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
G DCOE bog/hessitation Spridgets 46
G 1500 dual SU/ DCOE throttle cable question Spridgets 5
G DCOE trouble/qusetion Spridgets 10
J Ignition advance with Weber DCOE Spridgets 7
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
hondo402000 Weber DCOE jets needed[to borrow and return] Austin Healey 2
hondo402000 DCOE Weber jets needed[borrow and return Jaguar 0
hondo402000 TR6 TR6 40 DCOE Webers Jets needed to borrow them Triumph 3
hondo402000 TR6 TR6 Dialing in my Webers DCOE Triumph 2
M Rejetting weber 40 dcoe for 1275 Spridgets 1
DerekJ 45 DCOE Weber on BN1 Austin Healey 10
theleisure DCOE 40 Flooding Spridgets 6
DrEntropy 45mm DCOE Webers, anyone? Racing 1
T Jetting Weber DCOE for 948 and 1275 cc Spridgets 3
T Jetting a Weber 45 DCOE for a stock 1275 cc Spridgets 3
eschneider Weber DCOE help? Lotus 19
R6MGS Weber Sidedraft DCOE MG 10
Gray_Cat Know Someone looking for a Weber 45 DCOE? Spridgets 0
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
L TR4/4A Weber DCOE linkage for TR4 Triumph 4
scubabatdan Weber 40 DCOE 18 throttle problems on 73 Midget Spridgets 22
Jayrz HS2s VS 45 DCOE Spridgets 6
73MidgetLigon DCOE Trouble shooting Spridgets 32
73MidgetLigon DCOE Fun at Work...... Spridgets 2
73MidgetLigon DCOE 45 Jetting!!! Spridgets 3
1976Midget DCOE HELP Spridgets 14
1976Midget DCOE STUFF Spridgets 11
Baz Weber DCOE.... MG 16
L Big savings on Weber DCOE 45 carbs... Triumph 1
hondo402000 TR6 TR6 Weber 40 DCOE Latest friday 4-21 Triumph 2
J weber DCOE 45 carb a bad idea? Triumph 5
