Weber DCOE jets needed[to borrow and return]
hondo402000
When I rebuild my TR6 Engine this fall I will need to rejet my 40 DCOE Webers, actually they run rich now, however I wanted to see if any members that have extra idle jets, air correctors acc jets emulsion tubes etc, well all you have. its difficult to get webers dialed in since you have to purchase anything in sets of 6 to find out its not quite right and then you make a guess at what next to buy and then just give up getting it close. I do have a lot of different sizes too. So if you have left overs I can borrow and I will make sure you get reimbursed for the jets I keep and I will return the unused ones or buy and send you what I keep. PM me if you are interested and in return if someone else needs to do some experimenting I will let them borrow mine. Anyone interested PM me.
Hondo
AH100M
Didn't there used to be jet drills? You'd start with a lean jet and use larger and larger drills to increase the diameter until it got one size too large (rich). So then you'd buy one one step leaner? Worked for me on an Alfa I had back in the '70s.
R
RonMacPherson
There are jet drills and weber sells a jet measuring device. Why, because Weber recommends that the jets do NOT be drilled. Fuel jets are taper drilled.. Maybe for an air jet, but still the people who made the carbs don't want them drilled, then I won't drill 'em, unless it's for a competition emergency...
I believe it was Claude's Buggies, who first forewarned me of this years and years ago. They used to be extensively into Weber parts and setup...
hondo402000 DCOE Weber jets needed[borrow and return Jaguar 0
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
hondo402000 Weber Carburator rebuilding DCOE Triumph 14
bugedd Weber DCOE question Spridgets 43
J Ignition advance with Weber DCOE Spridgets 7
M Rejetting weber 40 dcoe for 1275 Spridgets 1
DerekJ 45 DCOE Weber on BN1 Austin Healey 10
T Jetting Weber DCOE for 948 and 1275 cc Spridgets 3
T Jetting a Weber 45 DCOE for a stock 1275 cc Spridgets 3
eschneider Weber DCOE help? Lotus 19
R6MGS Weber Sidedraft DCOE MG 10
Gray_Cat Know Someone looking for a Weber 45 DCOE? Spridgets 0
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
L TR4/4A Weber DCOE linkage for TR4 Triumph 4
scubabatdan Weber 40 DCOE 18 throttle problems on 73 Midget Spridgets 22
Baz Weber DCOE.... MG 16
L Big savings on Weber DCOE 45 carbs... Triumph 1
hondo402000 TR6 TR6 Weber 40 DCOE Latest friday 4-21 Triumph 2
J weber DCOE 45 carb a bad idea? Triumph 5
hondo402000 weber 40 DCOE carburators Triumph 5
K Weber 40 DCOE and a 1275 Spridgets 2
R weber 40 DCOE's Triumph 3
X weber 45 dcoe MG 8
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
