DCOE HELP
1976Midget
So i got the Dual DCOE on the Midget They started right up. But here the Problem. i have one barrel that pooring gas out of it and one barrel in the other a Big Road inside Part came flying out.
Frist Question what is the Piece and why did it come out and is this a Bad thing. looking at the diagram i provide here the Part is number 17
https://www.redlineweber.com/html/Tech/40-45_dcoe_parts_breakdown.htm
Second Question why is the one barrel pooring gas.
third Question the carb are running at about 3500 RPM right of the bat. the linkage is fully up when foot is off the gas. i assume this is an adjustment issue.
fourth Question any suggest on a braket for the Throttle cable
eschneider
pouring gas is probably a float height issue.
#17 may have come out if it wasn't seated? Maybe not an issue to re-install, but why did it come "flying out"? um, yikes?
also, you should be running 1.5-4 PSI of fuel pressure, preferably with a return line to the tank.
linkages - check out piercemanifold.com
R
RonMacPherson
From the picture you're describing the auxiliary venturi. Should be held in place by a lockscrew on the lower flank of the carb.
Time to pop them off again. Go over eachone, comparing them to each other. Something's radically not right. While you're comparing them. Use an airgun or can of compressed air(computer cleaner if nothing else) to blow through jets, emulsion tubes, fuel passageways, etc. Make sure your float levels are proper and that the float when lifted closes the needle and seat. Lightly blow through the fuel inlet while raising the float with your hand, holding the upper cover.
Make sure your throttle valves close completely, back off the idle set screws until they are not on the stops to verify closure of the valve plates, then turn the idle set screw 1 1/2 turn past contact for initial setting. Make sure your fuel pressur is under 3 psi. Make sure your fuel filter is clean.
1976Midget
1976Midget
i'll give it a whirl i am using a stock a Midget mechinal fuel pump. what psi does that produce. i guess i can get a fuel regulator
Platinum
On any DCOE ~except~ 45's the auxiliary venturi are held in place with a small "barrel" spring attached to 'em. If one "flew" out, it sounds as if you haven't any retainers at the front of the units. parts #18~21 are what keep things IN the barrels. If you've no air horns, the backing plate for the air cleaners would be doing this job.
Excess fuel out one barrel MAY be float level, but they're both fed with the same bowl, so I'd be looking for a main jet or emulsion tube not seated in the leaking side circuit... the other thing to look at are the accelerator pump jet seats.
The mechanical pump shouldn't overpower the float needle/seat.
Which DCOE's are we talking here? I thought they were 38's or 40's.
1976Midget
1976Midget
the one barrel the venturi flew out of was one that the air horn was removed. that explain that. they are 38's
1976Midget
1976Midget
Ive decided i am going to sell the dcoe and go back DGV style. i should get enough out of the dcoes to buy a new dgv
R
RonMacPherson
Have you looked at Teglerizer's site. He has a pretty complete site, with lots of links.
Just do a google for Teglerizer.
I believe that once a Weber is dialed in, clean fuel introduced, driven regularly and your problems are a LOT less than a Stromberg or SU.
jlaird
SU adjustments last for years and years. Nothing much to cause a problem as long as you check the dash pot oil from time to time.
Morris
I believe if you whack a weber with a sledge hammer, fill it with old paint and store it in salt water your problems are a lot less than with a Stromberg. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
R
RonMacPherson
You're entitled to your belief. That's what we enlisted and served for.
But I am entitled to disagree with you. AND I DO!!!
Zenith Strombergs don't even make good paperweights!. Simca,Mercedes.Brit mobiles. experienced on them a bit. And am so glad that they went away from them.
A weber is designed logically. And serves quite well. Plus a dialed in Weber sounds a lot healthier than a Stromberg.
The demand for Webers is such that when Weber quit making them for a while, they had to start building them again. Granted in a different country. But under Weber license.
Morris
Ron, I was agreeing with you. I just have a funny way of writing.
R
RonMacPherson
Mea Culpa, my initial perusal of your post got my ire going. I read it wrong. Sorry.
Morris
I especially agree with your statement about ZS carbs as paperweights. I have about 3 of them lying around my bench and every time I use one as a paperweight, all the carbon and grime built up from years of running too rich get all over my paper. It's totally frustrating.
Platinum
How can I fit a set of DCOE's up to a five hole Benz diesel?!? /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Every car on the list has DCOE's except poor Diesela. /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
eschneider Weber DCOE help? Lotus 19
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
N Dcoe???? Spridgets 9
N Dcoe????? Spridgets 1
PeterK TR4/4A DCOE air filters Triumph 5
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
sim air filter box for a DCOE 40 Spridgets 3
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Jetting a 40 DCOE for 1275 Spridgets 18
T Identifying vintage of a Weber DCOE Spridgets 4
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
sim High performance DCOE carbs 40 or 45 Spridgets 5
N DCOE double vs. single choke theory Spridgets 11
hondo402000 Weber Carburator rebuilding DCOE Triumph 14
bugedd Weber DCOE question Spridgets 43
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
G DCOE bog/hessitation Spridgets 46
G 1500 dual SU/ DCOE throttle cable question Spridgets 5
G DCOE trouble/qusetion Spridgets 10
J Ignition advance with Weber DCOE Spridgets 7
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
hondo402000 Weber DCOE jets needed[to borrow and return] Austin Healey 2
hondo402000 DCOE Weber jets needed[borrow and return Jaguar 0
hondo402000 TR6 TR6 40 DCOE Webers Jets needed to borrow them Triumph 3
hondo402000 TR6 TR6 Dialing in my Webers DCOE Triumph 2
M Rejetting weber 40 dcoe for 1275 Spridgets 1
DerekJ 45 DCOE Weber on BN1 Austin Healey 10
theleisure DCOE 40 Flooding Spridgets 6
DrEntropy 45mm DCOE Webers, anyone? Racing 1
T Jetting Weber DCOE for 948 and 1275 cc Spridgets 3
T Jetting a Weber 45 DCOE for a stock 1275 cc Spridgets 3
R6MGS Weber Sidedraft DCOE MG 10
Gray_Cat Know Someone looking for a Weber 45 DCOE? Spridgets 0
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
L TR4/4A Weber DCOE linkage for TR4 Triumph 4
scubabatdan Weber 40 DCOE 18 throttle problems on 73 Midget Spridgets 22
Jayrz HS2s VS 45 DCOE Spridgets 6
73MidgetLigon DCOE Trouble shooting Spridgets 32
73MidgetLigon DCOE Fun at Work...... Spridgets 2
73MidgetLigon DCOE 45 Jetting!!! Spridgets 3
1976Midget DCOE STUFF Spridgets 11
Baz Weber DCOE.... MG 16
L Big savings on Weber DCOE 45 carbs... Triumph 1
hondo402000 TR6 TR6 Weber 40 DCOE Latest friday 4-21 Triumph 2
J weber DCOE 45 carb a bad idea? Triumph 5
