Dashboard Warning Lights
BBH
On my BT7 there is a single green warning light in the middle of the dashboard to confirm that the indicators are working.
Anyhow, I would like to add in another couple of lights either side
- amber for oil pressure warning and
- blue for fog lights.
The question is where can I get the required lights in a similar style to the original?
I believe that TR4's had both a green and red dash warning light in the same style, but so far I have been unable to track down an amber or blue .... any idea's
Lucas WL3's would be a potential solution, but I would prefer to keep to the original style if at all possible.
B
BBH
Agreed. Indeed S-V-C have some "own brand" dash lights which use the same hole size and similar bezel, (which is my fall back position). However if I could source some exactly the same as the original green one, that would be my preferred route.
BN2guy
Hi BBH -
I have added warning lights to the dashboard of my BN2 for low oil pressure warning (red), and also an amber light to indicate that my driving lights are on. I found that the following light assemblies for Triumph TR2, 3, and, I think early TR4, match the style of the green turn indicator warning light on the BN2 dashboard, which I believe is the same as on your BT7. I found them at Moss Motors. They are Part Nos. 542-190 and 542-195 for Red and Amber, respectively. You'll also need get the sockets and bulbs which are Part Nos. 142-710 and 171-000. As for blue, I don't think I've ever seen one in the same style. I think that the MG TF used a blue light to indicate low fuel, but I believe that it's a different style light.
Anyway, I hope that this might help you.
Good Luck!
Bill
B
BBH
Bill,
Many thanks, just the info I was looking for. I suspect that the hunt for a blue light will be fruitless and I may have to follow your lead and use a red and amber (as well as the green indicator light).
maxwedge5281
my car is a v8 conversion so not original but, it is a very nicw car. im in the process of redoing the dash and saw this topic. thanks for posting and thanks for the info from bn2 guy. i just ordered the tr amber and red lights from moss. there is a bn7 currently on ebay with those lights. ill post a pic. thanks again
maxwedge5281
i recovered my dash and added the warning lamps from moss motors. my car is a v8 conversion so i updated the gauges as well...
maxwedge5281
thanks rick. time consuming to say the least. also wiring in a six circuit fuse block located behind the dash for some added electrical safety. the speedhut gauges and harness are really a hotrodders dream!!!
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
JohnGone MGB Wood Dashboard Kits MG 1
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
L Replacing veneer on wood dashboard Restoration & Tools 14
ckeithjordan TR2/3/3A Dashboard Covering Edge Clips Triumph 13
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
J Attaching new BJ7 Dashboard To Body Austin Healey 7
busybrit TR4/4A Steel dashboard color Triumph 1
K For Sale MG Midget Dashboard with Gauges Spridgets Classified 3
J BJ& MK ll 3000 Dashboard Austin Healey 2
A For Sale TRIUMPH 74 TR6 Dashboard w/Guages Triumph Classifieds 7
S TR4/4A How to finish dashboard? Triumph 19
Joe_Healey BN2 dashboard silver Austin Healey 0
busybrit TR4/4A TR4 Steel dashboard color Triumph 8
Sarastro TR4/4A What kind of wood and finish for the dashboard? Triumph 20
T Dashboard Knob Removal Spridgets 1
A TR6 Lettering on 1971 dashboard Triumph 1
wkilleffer MGB Dashboard pad replacement issues MG 3
AHS 1968 steel dashboard - can anyone confirm? Spridgets 3
W TR6 Dashboard Recommended finish Triumph 5
2billydavies TR2/3/3A clips under the dashboard that hold the vinyl covering on Triumph 4
H 1961 Mini MKI speedometer Housing pod & dashboard British Motor Corp 0
S Dashboard toggle switches for BJ8 - exact match? Austin Healey 12
K TR4/4A TR4A Dashboard Veneer? Triumph 13
K TR4/4A Veneering A TR4A Dashboard? Triumph 0
K TR4/4A Wood Finish on 4A Dashboard Triumph 9
2billydavies TR2/3/3A dashboard/instrument panel on 1958 TR3a Triumph 4
AHS TR2/3/3A Dashboard hole identification Triumph 8
MikeAH100M Center Support for 100 Dashboard Austin Healey 8
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
TR6BobNF TR6 TR6 Dashboard Hinge Question Triumph 3
R 100-4 dashboard color Austin Healey 1
R 100-4 dashboard removal help Austin Healey 4
Lbp TR2/3/3A New to Forum, New TR3 Owner, Dashboard Question Triumph 8
B MGB anyone have a good picture of a 78 MGB dashboard? MG 2
pkmh Removal and Refinishing BJ8 Wood Dashboard Austin Healey 41
Grannieannie Somerset dashboard Other British Cars 5
Patrick67BJ8 Additonal Gauge[s] for BJ8 Dashboard Austin Healey 13
Xte Original covering center dashboard and top dash ? Austin Healey 5
R Recovering BT7 dashboard Austin Healey 5
H Healey 100 Dashboard Color Austin Healey 10
Zimmycobra TR4/4A TR4A Dashboard question Triumph 5
af3683 Kienzle Dashboard Clock Triumph 10
Patrick67BJ8 Additional Gauges to a BJ8 Dashboard Austin Healey 6
middie Late model dashboard Spridgets 3
Zimmycobra Dashboard air vent grills Triumph 1
BugeyeNJ58 New gauges in Dashboard where radio goes... Spridgets 5
B TR6 best option for new TR6 dashboard Triumph 3
