Crossmember Pad Replacement
Lavo
Member
Hi Guys,
I am contemplating replacing the crossmember pads on my 1977 MGB. I believe there is a way of doing this without actually dropping the crossmember from the car but I can't find the method anywhere. I have already replaced the front suspension bushes with Poly, replaced the front wheel bearings and just want to finish the job with the crossmember pads. can anyone please help?
PAUL161
You have to jack up/support the transmission anyway, pull the four bolts and drop it. Makes life a little easier. JMHO. PJ
R Crossmember modification for DW Super Damper Austin Healey 11
B TR6 Gearbox mounting crossmember Triumph 10
B Wanted Late TR6 Gearbox frame Crossmember Triumph Classifieds 1
W Etype Ser. I front crossmember jacking Jaguar 3
JFS TR2/3/3A Front Crossmember Replacement Triumph 11
E Front crossmember drain holes. Austin Healey 3
M MGB Front MGB Chrome Bump crossmember MG 3
Stewart Changing crossmember pads MG 2
rick_ingram Front crossmember install MG 5
MGBGT_noob Stuck crossmember bolt MG 4
WillR crossmember removal? MG 13
kennypinkerton removing front crossmember... MG 13
D MGB MGB Front Crossmember Removal MG 15
PAUL161 Rear crossmember MG 6
Gatheringtree General Tech Custom kick pad Triumph 5
kodpkd Disc Brake Pad Installation Austin Healey 11
AUSMHLY Overdrive Buffer Pad Austin Healey 3
K TR2/3/3A Brake pad Question Triumph 3
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
EWD TR6 Dash Pad Replacement Triumph 3
J TR6 TR6 Brake Pad Shims Triumph 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
D Gas Pedal Pad Jaguar 7
ckeithjordan TR2/3/3A Brake Pad Recommendations Triumph 1
roscoe Brake pad question Austin Healey 3
S TR4/4A Dash Pad Triumph 3
dklawson General Tech Brake Pad Brands and Materials - Advice Wanted Triumph 11
N TR4/4A TR4A door crash pad Triumph 11
Griz Dash Pad Austin Healey 8
JimTR4 TR4/4A Top dash pad vinyl is "puffy" Triumph 2
Rut TR4/4A Lower crash pad Triumph 9
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
G TR4/4A Crash Pad Question Triumph 8
T TR4/4A Attaching top dash pad on a Tr4a Triumph 8
wkilleffer MGB Dashboard pad replacement issues MG 3
M TR4/4A Left lower dash crash pad. Triumph 5
BOBBYR BJ8 top dash pad removal Austin Healey 9
H Dash Pad Clips - BJ7 Austin Healey 3
R ceramic or semi-metallic brake pad? Spridgets 3
tomshobby installing new dash pad Spridgets 10
T TR4/4A Rotor,caliper and Pad replacement TR4 Triumph 7
TRMark Brake pad suggestions Triumph 16
R Dash pad question Spridgets 7
NutmegCT TR2/3/3A TR3 battery pad? Triumph 8
I Need tracing for passenger side 69-72 kidney pad Triumph 7
I More kidney pad questions Triumph 0
I TR6 TR6 kidney pad installation help please Triumph 7
I TR6 Need measurement for tr6 kidney pad please Triumph 4
