removing front crossmember...
OK, I think I'm going to attempt it this weekend (if it stops raining for a while).
After I disconnect the front brake hoses, and remove the 4 bolts, is there anything else holding or hanging onto the front crossmember? What holds the cardboard sheild on - screws or rivets?
tony barnhill
Great Pumpkin - R.I.P
Steering rack - Front sway bar.
Look up underneath the cardboard mud guard & you'll see a little bolt with a nut on it in the center.....in addition to the screws along the edge back up on top.
Be careful that the bolts holding the crossmember come out easily - the one closest to the exhaust is probably rusted solid & you may have yo undo it from underneath.
kennypinkerton
Thanks Tony. I forgot about the swaybar. Isn't the steering rack mounted to the crossmember?
Gonna spray the bolts down with PB tomorrow evening when I get home from work.
I guess I need to tighten the nuts on the motor mount whil I've got it all out. I need to find my new driver's side motor mount around the house here too. It's been here for 5 years, forgot where I put it :crazy:
I figure that new bushing kit I got from you will go on easier while sitting on the front porch instead of me laying on my back with the fireants :laugh:
tony barnhill
Steering rack is mounted to crossmember but you have to loosen it from the column & with it attached to the crossmeber, you'll have to drop the member down & forward.
Steve_S
Yes it is. Might I also suggest you disassemble the suspension while the cross member is still on the car? It makes removal of the beam almost a one-handed job, versus a 100-pound awkward lump. It also gives you more leverage to tweak on things, and makes coil spring removal far easier for those without a spring compressor.
Steve_S
I typically unbolt the rack from the cross member, tie it up out of the way, and leave it there while I pull the cross member. Of course you have to pop the tie rods off of the steering arms but that's easier than disconnecting the steering column and it has to be done anyway.
tony barnhill
I agree its easier to disassemble while on the car if you're gonna rebuild & put back under the car...however, I've never had any problems disassembling on the floor....& have never had a spring do anything except pop the spring pan down a little & fall out onto the floor (that's usually how I disassemble parts car front suspensions - some time after I drop the beam when I need a particular part off the beam.)
mgb4tim
be careful. That's just what I did. I pulled out the front suspension to rebuild it.. then look what happened...
RTR52nd
Tim -
I'm curious, did you remove the unibody to make it easier to work on the suspension from the top? :jester: I'm about to pull my front suspension out, but if you think it's easier your way, I'll try it and let you know how it goes!
jlaird
Looks like he had a heck of a time finding the right bolts
Now that's a SERIOUS case of getting attacked by the Might-As-Wells.....heck, you got attacked by a whole planet of them!!! :laugh: ROFL
kennypinkerton
I have neither the money, nor the time. I'll just stick to the stuff I can afford. Although in a few years, the Alfa may look like that.
"your unibody fell off"
:lol:
Was probably trying to find out how to get to the bonnet hinges... "Hmmm, maybe if I take that off I can get to them..."
tony barnhill
sorta like my little Midget that went down to tub just to change the clutch!
B TR2/3/3A Removing front trunnion Triumph 15
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
KVH TR4/4A Removing Front Transmission Seal Triumph 1
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
catfood Removing front hub Austin Healey 6
drooartz MGB-GT Question - removing front bearings MG 2
S Problem removing front wheel bearing retaining nut Austin Healey 9
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
J TR2/3/3A Removing front spring pans? Triumph 6
T Question on removing drivers front lower wishbone Triumph 7
B TR2/3/3A Tr3 removing front wings Triumph 8
deadair TR2/3/3A TR3A -- Removing front brake pistons Triumph 19
G Advice needed in removing front left fender. Triumph 2
A removing front apron Triumph 10
T TR4/4A Removing TR4a front rotors Triumph 5
Number_6 TR2/3/3A Removing front fenders on a TR3 Triumph 20
J Removing front bonnet - MKII Austin Healey? Austin Healey 4
bighealeysource Removing front shocks on a 100 -4 Austin Healey 12
N Removing Front fender MG 4
DanZ_BT7 removing the front discs Austin Healey 4
T Removing front fenders & hood Triumph 10
HAN8L1965 Removing Front Springs 65 Sprite Spridgets 1
J Removing top fulcrum pin on front suspension. Austin Healey 2
A Spitfire Removing cap over front hub on Spit Triumph 2
tr6web TR6 Need advice removing downpipe nuts Triumph 0
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
