Etype Ser. I front crossmember jacking
why
I have often seen referred to and a recent XKs unlimited mailing showed a piece of wood that fits into the front crossmember and can be used as a central jacking point for both front wheels. Over the 28 yrs of ownership I have stared at this crossmember, on my late l967 series 1 this crossmember has the radiator bolted to it in two places, out at the ends it is attached solidly to a from tube at each end. I have never considered this a good jacking method since the crossmember itself is flimsy to raise weight of front of car and feared any wood placed within in it would have to be strong enough not to flex and put pressure upward through radiator damaging it, all the weight would be focused on the very end inch or so of the wood. In addition, the bolts holding the radiator on protrude through the crossmember and into the space occupied by the wood, so the wood would need holes/indentations to allow the bolts to penetrate into the space, further weakening the woods ability to support the entire front end of the car simply on its two end points. Called Xks and parts guy referred me to technical guy who will call back. Anyone have experience with such a way of jacking car up, my crossmember is in good shape with just slight warp from end to end, someone may have tried to jack up from there and saw it would not work. All of this assumes I put jack under center of wood as opposed to using 2 jacks, one at each end.
Thanks, Jay, '67 Series 1, roadster
Geo Hahn
As you figured out (in your other post) the block and jack use the picture frame, not that cross piece below the radiator. The wood block is the way to go here - either one offered by the usuals or homemade. Mine is made from a piece of Trex and labeled to try to make it as idiot proof as possible:
MikeP
And for those who may wonder, the block of wood is to keep the flanges on the bottom of the picture frame from getting bent when jacking.
LarryK
Jaguar's factory service manuals say to use the wood block.
AngliaGT Bugeye,Jag eType,Citation,Fiesta,etc. Spotted 1
Basil Series 1 EType Spotted 2
Basil Back to the EType finally Jaguar 5
W Etype lower ball joint removal Jaguar 14
Basil Wow - EType breaks auction record! Jaguar 0
HEALEYJAG 73 etype roadster seat belts Jaguar 1
W EType Temp Gauge Jaguar 6
Basil EType Tie-rods Jaguar 2
Basil More Drool. A 3.8 Flat Floor EType! Jaguar 13
Basil Met a local guy with an EType Jaguar 7
Basil POsted pics of 63 EType Jaguar 0
W Etype Chrome Strip Windshield Gasket Jaguar 2
D retro-fit 1970 etype with three carb set-up Jaguar 3
Basil Jaguar EType Documentary Jaguar 1
B EType steering question Jaguar 6
C Battery for my 64 Etype coupe 3.8 Jaguar 10
KenASh Etype mufflers Jaguar 0
Basil MGB MGB beat my beloved EType! MG 13
KenASh Etype rear brake calipers Jaguar 13
Basil Slight problem with rear hubs [EType] Jaguar 7
Basil Gun metal gray EType spotted Jaguar 12
Basil EType Owners List Up-dated Jaguar 0
Basil EType Owners list Latestd Jaguar 2
Basil Ok, I've started back on the EType! Jaguar 23
J Shopping for a EType - what to watch for? Jaguar 13
D Purchasing a 66-68 EType Jaguar 5
P etype roadster interior Jaguar 0
P classic auto insurance 69 etype Jaguar 5
P etype OTS 69 seat pans Jaguar 1
J What is a Series 1 1/2 EType ?? Jaguar 13
Basil Finally back to my EType Project Jaguar 11
glenwilcox Lost Love - 1955 RHD 100-4 Ser. 219049 Austin Healey 1
J Rear glass install. Ser. 1 XKE? Jaguar 5
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 3
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
