retro-fit 1970 etype with three carb set-up
donmac
I have intstalled a three carb set up on my 1970 E Type. Having trouble getting the manual choke to work with out binding. Anyone have any ideas on the subject.
Don Mac
LarryK
Make sure line is as straight as posssible with no hard turns. Maybe lube cable housing with silicone or powdered graphite ( one or other ). Does the choke work by hand with the cable unhooked? Check throttle plate clearances make sure they move OK and check the main jet is centered. I am assuming SU setup?
Platinum
Can you supply a few detail photos? There are a number of things which will cause the thing to bind up. Is the cable a solid one or multi-strand? Have you a manual detailing the proceedure to set it up?
Just trying to get info to guide ya.
Platinum
Hiya Larry! I think we could safely assume SU's but ya never know. :wink:
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
GTP1960 "Classic Cars of SC" a Retro car lot/junk yard Other Cars 1
R Retro Radio MG 4
Scott_Hower E-type retro by Lyonheart [aka Growler] Jaguar 1
Hap Waldrop NEW VTO Retro 4 14x5.5 for Spridgets Spridgets 25
Hap Waldrop VTO Retro 4 vs VTO Classic 8 Triumph 40
Hap Waldrop MGA New VTO Retro 4 wheels now in 15x6 for MGA/B MG 2
Hap Waldrop New VTO Retro 4s Triumph 24
Hap Waldrop First peek, New Retro 4 Spridgets 50
Hap Waldrop First peek, New Retro 4 MG 6
Gundy retro tach source? Spridgets 33
I Carb Overhaul for retro fitted 1954 100M Austin Healey 1
kch Building Healey engines in may issue of Retro Cars Austin Healey 3
Bret So Sammy B, what about that bad word: RETRO! Other Cars 22
kch Retro Cars, MG with S2000 engine. MG 4
J Mini's retro look proves to be a big hit British Motor Corp 2
Simmo MGB Will Wings (Mud Guards) fit? MG 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D TR2/3/3A Windshield glass doesn't fit Triumph 6
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
R Wire Wheel Fit Austin Healey 10
D Door Seal Fit Austin Healey 18
R BUGEYE SOFT TOP FIT Spridgets 2
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
chicken BJ7 Door Fit Austin Healey 27
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
S Rear Wing Fit Austin Healey 4
69MGC MGC What size tires will fit nicely MG 2
J Top Trunnion Bushing Fit Austin Healey 9
M TR4/4A Do MGF seats fit in TR4 Triumph 0
P Seat Bottoms And Bases Don't Seem To fit Together Well Austin Healey 4
K TR2/3/3A Control hedd fit? Triumph 1
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
S TR2/3/3A tr3 spare tire fit Triumph 16
T XK120 fit 140 rack & pinion Jaguar 3
L TR2/3/3A Liner spigot fit? Triumph 13
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
P top frame fit Spridgets 5
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
AngliaGT Rubber Gasket - What's it Fit? British Motor Corp 3
anarchy99 Bonnet / hood fit question... Spridgets 2
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
P Question about BJ7 Shut Face Finisher Fit Austin Healey 3
TulsaFred New Bugeye Seat Covers from AH Spares don't seem to fit properly Spridgets 10
D TR2/3/3A Gas tank does not fit! Triumph 4
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
