TR2/3/3A Brake Pad Recommendations
ckeithjordan
Anybody have any experience, good or bad, with Moss' Gold-series semi-metallic or ceramic brake pads? I'm thinking of replacing my pads with an "upgrade." Any other pad recommendations?
TR3driver
Great Pumpkin - R.I.P
I've no experience with the Moss product; but I heartily recommend the "Kevlar" pads and shoes sold by Ted Schumacher (TSi).
http://www.tsimportedautomotive.com/tr3_tr4a.html
Unlike some other "performance" materials, they offer excellent performance when cold as well as hot. Seem to be reasonably gentle on rotors (some materials wear rotors almost as quick as pads), and generate only a moderate amount of dust. (Not none at all, but less than EBC 'Greenstuff')
And while I'm sure there is a limit, I've never experienced brake fade with them, even driving pretty hard (or 1st in class at the VTR autocross).
My only complaint (which isn't really the pads fault at all) is that if I get startled and jab the pedal hard, it's easy to lock up the front tires. But they're easy to modulate, as long as the driver doesn't panic.
BTW, using the "braided stainless steel" lines (also from Ted) will reduce pedal travel and improve feel. Also a worthwhile improvement IMO; especially if you run DOT 5 brake fluid.
kodpkd Disc Brake Pad Installation Austin Healey 11
K TR2/3/3A Brake pad Question Triumph 3
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
J TR6 TR6 Brake Pad Shims Triumph 1
roscoe Brake pad question Austin Healey 3
dklawson General Tech Brake Pad Brands and Materials - Advice Wanted Triumph 11
R ceramic or semi-metallic brake pad? Spridgets 3
TRMark Brake pad suggestions Triumph 16
S What is the best brake pad? MG 12
B MGB GT V8 brake pad part number Racing 1
T Wheel hard to turn after brake pad change Triumph 9
jerrybny Classic Gold Semi-Metallic Brake Pad Set Triumph 2
drooartz Brake pad choices Spridgets 6
T Brake Pad Shims Triumph 4
kodanja Gimme a Brake..............Pad Triumph 15
H BRAKE PAD SQUEEL PROBLEM? Triumph 19
R Brake Pad Noise Triumph 7
M Brake Pad Triumph 8
bash Brake pad retaining pins Triumph 1
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
