Cooling System
QuickSilver
I am missing what appears to be the following Moss part numbers on my steed:
68 458-195 $30.95
MUD SHIELD
69 475-255 $44.95
LOWER AIR DUCT PANEL
40 282-905 $4.95
SEAL, radiator to support
1968-76
Will these after my subpar cooling performance in 100 degree weather in Dallas?
tony barnhill
Great Pumpkin - R.I.P
You need all 3....every piece of the cooling system has an important role to play in keeping an MGB cool....without one, the system doesn't work effectively.
QuickSilver
QuickSilver
Excellent, thanks gents.
I have one last question.
Could I expect to drive my MGB in 110 degrees outside weather and not have the temp gauge approach the red zone or this is a fruitless effort?
tony barnhill
Yep! My '79 is totally stock & never overheats in any type weather...I've driven it from Kansas to San Antonio in the hottest of weather; from Kansas to Mississippi in blowing snow; all across Canada & Alaska & in everyday traffic.....if the setup is correct, it should operate just like any other car.
davester
I don't have any of those parts on my '71 GT and the Moss part number listing only shows that
40 282-905 $4.95
1968-76
is needed for my year. I can't recall seeing any of these parts on any Bs and I just looked through a whole slew of engine compartment pix on google and can't see them there either. However, my GT does seem to be running hot, and this after a backflush, new thermostat, tuneup, etc. Is there any easy way to quickly fabricate that part...what is it made of exactly and does anyone have pictures. If I can make it out of something laying around the garage that would save me the hassle of ordering from Moss.
Another thing...since my car got back on the road last week, the temp gauge has been up above the 3/4 mark. I'm wondering if it is really overheating or if that is simply a bad sender. Has anyone figured out a good way to calibrate the sender/gauge? I have one of those digital thermometer BBQ forks and had a thought that there must be some easy way to tap into the coolant flow with it while the engine is running.
QuickSilver
QuickSilver
tony barnhill said:
Yep! My '79 is totally stock & never overheats in any type weather...I've driven it from Kansas to San Antonio in the hottest of weather; from Kansas to Mississippi in blowing snow; all across Canada & Alaska & in everyday traffic.....<span style="font-weight: bold">if the setup is correct, it should operate just like any other car</span>.
Thank you, that's what I wanted to know.
QuickSilver
QuickSilver
40 282-905 $4.95
1968-76
I thought mine might be a bad sender too and still might be but on cooler days it runs right at the mid mark but as we creep into the 90's and with any sort of spirited highway driving then it's almost pegged at H.
tony barnhill
What's the VIN on your car?
The mud shield goes in the open area between the radiator & the front of the engine on all B's after # 410001, &
The lower air duct panel goes under the radiator lower duct panel on all chrome cars.
davester
Tony, my VIN is 246081
The Moss catalog indicates that the lower air duct panel is only for "RD from 360301 to 410000". It doesn't say anything about GTs though I can't understand why the RD would have one and the GT not. I also cannot for the life of me figure out where it attaches or what its purpose is. Which "radiator lower duct panel" are you talking about? My radiator base fits pretty tightly against the panel that the oil cooler is attached to. Where would this lower air duct panel go?
tony barnhill
So, you don't need the mud shield because you're radiator is rearward.....My '67 & '74-1/2 GT's have a lower air duct panel...it's fits under the radiator forward to the hole in the valance, bolting under the frame rails at the front....all MGB's with holes in the valance & the radiator in the rearward position should have one.
T TR2/3/3A Help - Cooling system problem Triumph 7
steveg TR6 Cooling system filling Triumph 7
D Trying to understand my cooling system Austin Healey 29
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
7 stupid plastic cooling system parts Other Cars 2
mgedit TR2/3/3A Cooling System Flush Triumph 32
NutmegCT Cooling system clean/flush Restoration & Tools 11
steveg Cooling system filter installation - xpost Austin Healey 6
richie TR4/4A TR4a Cooling system temperatures Triumph 10
mgedit TR2/3/3A 56 TR3 Cooling System Triumph 2
T XKE Series 2 Cooling System Jaguar 0
RJS Cooling System Flush Triumph 3
hondo402000 TR6 flushing your cooling system, TR6 car specific Triumph 14
Moseso TR2/3/3A TR3 Cooling System Mystery Triumph 4
Dadandson Cylinder Head and Cross flow Cooling system Spridgets 12
KVH Air Pockets in Cooling System? Triumph 7
eschneider Favorite cooling system flush chemicals / brands? Restoration & Tools 3
martx-5 TR2/3/3A TR3 Cooling System Capacity Triumph 5
J oil in cooling system Austin Healey 11
T TR2/3/3A TR3 Cooling system Triumph 15
M Cooling system - thermostat Austin Healey 16
JPSmit Cooling System Question -1500 Midget Spridgets 3
S dish-washer soap in cooling system Triumph 11
Baz Heater box / cooling system Spridgets 8
John_Mc Cooling system flush question part 2 Triumph 3
John_Mc Cooling system flush question Triumph 1
S Wedge Oddities of the TR7 cooling system Triumph 1
sparkydave Darn cooling system! Spridgets 11
N Removing Cooling System Bubble Austin Healey 11
G Filling a completely dry cooling system.... Triumph 13
G Refilling the cooling system . Triumph 1
S Cooling System Question... MG 5
J Cooling System Austin Healey 15
J motor oil in cooling system-100/4 Austin Healey 4
Deanrobert Xke series lll cooling issues Jaguar 5
T TR2/3/3A Water pumps/head cooling Triumph 22
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
D BT7 air ducting / cooling Austin Healey 20
brgrmyster GT6 Original GT6 Mk 1 cooling fan Triumph 24
F Cooling Austin Healey 3
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
R TR2/3/3A Non Triumph cooling question Triumph 8
apbos Parade Cooling Help Spridgets 12
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
D 2.4L internal cooling passages? Jaguar 4
J Another what cooling fan is this question? Austin Healey 47
H Denis Welch cooling fan arrived today Austin Healey 2
