Removing Cooling System Bubble
noutlaw
Member
I believe I have a bubble in my cooling system. It was nice enough on sat to take the car for a drive. (68F/Sunny - colorado). When driving, car was running @ normal temps, however when I slowed down/stopped the temp would run up (220-230) almost immediately, start going again and it goes right back down...
My suspicion is a bubble because there's no way the water was going from 180 to 230 in 20-40 seconds...
Anyway - I wasn't sure if there was a higher level bleed (heater?) that i could use to see if there is in fact some air in the system and more importantly how to remove it...
Keoke
Noutlaw, has the cooling system been serviced ; radiator boiled out and rodded,pump in good condition, block been flushed out recently and is the fan belt adjusted properly. Overheating as you described is typical of some Healey stock cooling systems.---Keoke
shorn
I think flushing the system would be a good idea if you haven't done that in the last few years. There could be alot of rust/sludge in the water passages of the block. First, though take your car to a recommended radiator shop. They will have an infared sensor to determine if the radiator is cooling properly. They may also have better flushes than you can buy at auto zone. Removing the Healey radiator is not difficult, should that be recommended for rodding/flushing.
But, it is not unusual for the temp to go up when you shut off the engine, although from your readings, yours is higher than normal,and it shoudn't shoot up that high just slowing down, unless the fan belt is loose and not turning the water pump properly or the w/p is bad. Remember that the temp sensor is in the engine block. Once the car is shut off, so goes the water pump, and the coolant in the engine heats up rapidly because it is stuck there, surrounded by hot metal. Your running temp seems normal, but I think when the car is shut off, the temp shouldn't go up more than about 20 degrees.
BlueRidge1
What kind of fan do you have? You may want to upgrade to a better fan If you are using the stock fan. What model is your car? I know a bn7 had a fan that wasn't all it should be. Bob
Keoke
BOB, I know a whole bunch of Healeys that had fans that weren't what they should be.---Keoke- /ubbthreads/images/graemlins/laugh.gif /ubbthreads/images/graemlins/angel.gif
Michael Oritt
Before going too far it might be wise to invest a few dollars in a candy thermometer and verify that the temperature guage readings are accurate. Perhaps the fan is mounted backwards?
N
noutlaw
Member
Hey guys thanks for all the input - I've been off line a couple of days...The car is "brand new" completely rebuilt - BJ8 and a 6 bladed fiberglass fan.
So the system is clean, new radiator core, hoses, etc.
What it appears to be is that the thermostat is sticking... I went for another drive and it was running fine - came to a full stop and temp held fine - then drove some more and came to a stop and suprise it started going up... drove around in 2nd (15 mph) and it was going up... so shut it down all together...
The benefits of working out "new car" kinks.
Guy who rebuilt car is Knut Holzer of British Motor Corp in Phila, PA. (if you look on harwood-enterprises, there is a recently sold golden beige car 1967 3000) that was done by Knut as well.
Keoke
Don't sound like thermostat sticking to me Noutlaw. Why not call the guru and see what he thinks??.---Keoke /ubbthreads/images/graemlins/yesnod.gif
N
noutlaw
Member
Re: Removing Cooling System Bubble --- Keoke..
Keoke - (just for closing the loop)..
Turns out it was a faulty gauge on the car... did digital thermostat on the engine and it's running fine. Getting new replacement... /ubbthreads/images/graemlins/smile.gif
Thanks for the input.
Keoke
/ubbthreads/images/graemlins/thumbsup.gif----Keoke
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
tr6web TR6 Need advice removing downpipe nuts Triumph 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
