TR2/3/3A Non Triumph cooling question
RonR
I have a car that overheats when stopped for short time periods, like at stoplights.
Radiator is full.
Electric fan works at idle
Since the car cools down once it is moving, I am assuming the water pump is working.
The temperature sendng unit is on the engine, not the radiator.
Thanks for your help.
Ron
M_Pied_Lourd
Well, with the car moving you are getting air/cooling through the rad...doesn't necessarily mean that your water pump isn't bad....
Have you done a full coolant flush lately? Could be lots of sediment in the coolant passages/rad etc.
Cheers
Tush
Merlin63Tr4
If it's a modern car, it could be the water pump's plastic impeller freewheeling on the water pump shaft.
They don't move much coolant when that happens....
M.
TomMull
Might help to know what the car is. Might also post under "Other Cars". Some cars, e.g. my BMW, have an electric fan in addition to the engine driven fan. Both need to be working properly or overheating at slow speeds will occur. On this car the engine fan is a viscous drive and those are prone to failure.
Tom
Geo Hahn
Could also be a partially blocked radiator - can sometime be diagnosed by pointing an IR thermometer at various location on the hot radiator. This problem is more likely in a car with age & high miles.
R
RonR
it's a Honda DelSol.
it only has electric fans, one for the radiator and one for the condenser.
The condenser and radiator sit side-by-side.
A blocked up radiator is a possibility. I had a 1984 Civic where that happened.
Although a radiator cost a lot more than a water pump, it would save me a lot of time if all I had to do was replace the radiator.
The car has a air bleed screw, near the thermostate housing, for the coolant system. I think if I open this bleed screw after the engine is running, water should really shoot out if the water pump is working.
Thanks for the comments.
Ron
TimK1955tr2
I would check the radiator for cracks, I think those may have plastic top and bottom sections. I had a 1997 Civic develop a crack and it showed the same symptoms. A hairline crack would not allow the pressure to hold, reducing the cooling capacity especially once it gets hotter like at a light or stop.
I replaced with an Autozone one and it has been fine for the last year, I don't it cost more than $100?
T OT - Non-Triumph transportation last night Triumph 1
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
Fanch00 Non-Overdrive Benefits? Austin Healey 10
Celtic 77 MGB Non working tach. MG 4
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
J TR2/3/3A Adjustable vs non Adjustable wheel Triumph 0
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
AUSMHLY SU Damper Cap Vented vs Non-Vented Austin Healey 25
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
C Non-Adjustable steering column questions Austin Healey 14
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Synchro in a non synchro? Triumph 19
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
maxwedge5281 Trafficators, Adjustable vs. Non-Adjustable Austin Healey 14
Jim_Gruber Non LBC but saw my first Civic Type R Yesterday Spridgets 24
Zitch TR4/4A OD Addition to a Non Over-Drive Transmission - my attempt Triumph 11
Rut Interesting non Spridget Spridgets 3
NutmegCT The non-garage garage Restoration & Tools 22
Marla TR4/4A Ballast or Non... Triumph 6
B Posting non you tube video? FORUM Navigation Questions 3
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 2
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 0
C TR6 Non-start diagnosis Triumph 9
GTP1960 TR2/3/3A Resistor plugs vs. non-resistor plugs? Triumph 6
nevets interesting piece in the NYT about collector car non-restoration Austin Healey 5
vette Detergent/Non-detergent Austin Healey 19
AUSMHLY Best 7" non sealed headlamp Austin Healey 19
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
CJD TR2/3/3A Adjustable vs Non-adjustable Control Heads Triumph 4
P I need a non-working electric tachometer for parts Spridgets 0
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
vette Detergent or Non-Detergent, Trans/ OD Austin Healey 7
Boggsy64 MGB Starter - Non starter? MG 16
K TR2/3/3A Trunnion spindle cotter pin hole non existent! Triumph 9
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
S WTB: Non-Adjustable Horn Button for a 3000 Austin Healey 6
H horn button for BN6 "non-adjustable" Austin Healey 4
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
johnrip Wedge TR7 non-idle Triumph 4
