Detergent or Non-Detergent, Trans/ OD
vette
Hi all, Can someone tell me the reason it is recommended to run non-detergent oil in our trans and ODs. Thanks, Dave.
British_Recovery
Bronze
Early gearboxes have parts that might be compromised by detergents, so I use 30 wt. non-detergent. Center shift 'boxes appear to allow multi-grade detergent oils (factory handbook) as used in the engine, so I use 20w50 GTX in the BJ8. No need to worry about ZDDP here. This is what I have concluded after years of debate and questions, and it seems to be working.
Bob
5
57_BN4
Had this discussion a few weeks back. Best reason given is because detergent oil tends to foam more and this can reduce OD hydraulic pressure.
I'd tend to agree with the foaming thing as I run regular multigrade detergent engine oil in the 57 OD and the oil turns a light-brown opaque colour after running for a few minutes. OD works fine although the shift is quicker and sharper after sitting overnight compared to after being driven within the last few hours which I'm guessing is related to oil foaming and viscosity. The softer shift is more pleasant to drive.
Andy.
RAC68
As Bob and Andy indicated, foaming is one reason for not using detergent oil. However, the major reason is that the Trans/OD does not have a filtration system and non-detergent oils will allow any particles or metal bits to drop out of suspension and settle to the bottom of the case (out of harms way) for elimination when draining. Detergent oils are formulated to keep these particles in suspension (to be taken out by a filtration system) and will constantly circulate and possibly cause further damage.
Ray (64BJ8P1)
Quantum Mechanics claims use of detergent oil will void the warranty on their rebuilt trans and overdrive units; same reasons cited above.
I'm currently using Shell 30 ND in my car, and the shifts are crisp (and instantaneous)!
vette
vette
Thanks Everyone. I decided to read the manual alittle. I do this once in a while :smile:. The manual talks about different weights and temps, etc, I was even alittle surprised that it mentions multi-weights for some conditions considering the era we are talking about. But the manual says nothing about detergent oils vice non-detergent oils. I was wondering where the recommendation came from. Your responses all make sense to me because I am experiencing same kind of situation. I'm running Valvoline 20w/50 Racing Oil in the engine. But I put 30w Valvoline in the trans and OD. I assume it is a Detergent oil. I noticed immediately upon putting it on the road this fall that the upshift into OD was not crisp at all. And twice at highway speed it dropped out of OD by itself then immediately reengaged. So I think I should switch to a non-detergent oil. Have a Merry Christmas. Dave.
John Turney
... And twice at highway speed it dropped out of OD by itself then immediately reengaged. So I think I should switch to a non-detergent oil. Have a Merry Christmas. Dave.
Mine started doing the dropping out of OD on the highway and reengaging shortly thereafter last Spring. It was an electrical issue. I replaced both the relay and solenoid and it went away.
Had same problem one time--was the relay (the one on the scuttle/firewall). You can open them up--carefully--file the points and close them back up. If that fixes the problem put a new one in as the points may be very worn.
vette Detergent/Non-detergent Austin Healey 19
SCguy 30 weight oil non-detergent? Triumph 8
aeronca65t "Soap" vs "Detergent"? Restoration & Tools 7
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
Fanch00 Non-Overdrive Benefits? Austin Healey 10
Celtic 77 MGB Non working tach. MG 4
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
J TR2/3/3A Adjustable vs non Adjustable wheel Triumph 0
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
AUSMHLY SU Damper Cap Vented vs Non-Vented Austin Healey 25
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
C Non-Adjustable steering column questions Austin Healey 14
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Synchro in a non synchro? Triumph 19
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
maxwedge5281 Trafficators, Adjustable vs. Non-Adjustable Austin Healey 14
Jim_Gruber Non LBC but saw my first Civic Type R Yesterday Spridgets 24
Zitch TR4/4A OD Addition to a Non Over-Drive Transmission - my attempt Triumph 11
Rut Interesting non Spridget Spridgets 3
NutmegCT The non-garage garage Restoration & Tools 22
Marla TR4/4A Ballast or Non... Triumph 6
R TR2/3/3A Non Triumph cooling question Triumph 8
B Posting non you tube video? FORUM Navigation Questions 3
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 2
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 0
C TR6 Non-start diagnosis Triumph 9
GTP1960 TR2/3/3A Resistor plugs vs. non-resistor plugs? Triumph 6
nevets interesting piece in the NYT about collector car non-restoration Austin Healey 5
AUSMHLY Best 7" non sealed headlamp Austin Healey 19
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
CJD TR2/3/3A Adjustable vs Non-adjustable Control Heads Triumph 4
P I need a non-working electric tachometer for parts Spridgets 0
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
Boggsy64 MGB Starter - Non starter? MG 16
K TR2/3/3A Trunnion spindle cotter pin hole non existent! Triumph 9
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
S WTB: Non-Adjustable Horn Button for a 3000 Austin Healey 6
H horn button for BN6 "non-adjustable" Austin Healey 4
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
