TR6 Non-start diagnosis
Crisis
Good Morning Forum Members,
I am having trouble with my 73 TR6 and was hoping the forum could help me figure out what is wrong. Background: car started to accelerate badly and at first seemed to only be a problem from stop. Then, I was lucky to get it home as I could not build enough revs to give the car any power. I let the car sit for a while, check gas flow north of filter, check gas flow immediately before carbs (squirt into jar). Tested for spark at plugs (inline tester), cleaned plugs, tested compression (130-148 psi), had 12 volts at + side of coil. Car turned over freely and strongly. All seemed ok. Started car (this is a week later now) and took for test run. Ran beautifully and quite strongly up to my turnaround point. Started heading back to house (10 miles +-), car started to die, huge backfire from tailpipe and stopped. Got her towed home on a deck. Still have spark at plugs, still have fuel at carbs (pulled plugs at bottom of float bowl and a lot of gas dropped out), 12+ volts at coil. Turns over strongly but you can just feel that nothing is going to happen.
Any thoughts? Thank you.
C
Crisis
Have not checked them, however, they are fairly new. And, car doesn't even catch a little bit now. Turns over strong but you can tell nothing is going to happen. I can check diaphragms tomorrow to be sure. Thanks!
LarryK
Ignition wires at coil and/or points?
Check spark plugs. The ones now a days ever get wet they are trouble to work again. Sounds crazy but its happened to me a couple of times. Plugs are cheap, put another set in and see if that helps. Electronic ign or points?
marv
C
Crisis
Good spark going to the plugs. I use one of those inline plug testers with the window, and I can see a good spark going to each plug. Wouldn't that mean coil was getting power and then sending large volts to distributor, and then to plugs in turn?
My car has a Lumenition electronic ignition system. Small metal box screwed to bulkhead under wiper motor. Wires go to distributer in a small loom with multi wire connector. I suppose it could be malfunctioning? Don't know much about it but has worked infallibly for my 15 years of ownership. Spark is at plugs but I guess it could be in the completely wrong order? My "feeling" is it is electronic because of the huge tailpipe backfire when it quit, and the fact that it doesn't even catch a little bit when it turns over now.
Thanks Tdskip and Larry K.
charleyf
Try changing out the coil. When the coil gets hot ( after 10 miles) then it could be a problem. By the time you get the car home and start checking it out it is cool again and works fine. When my coil died one day I got the huge backfire. I decided that it was not giving any spark and then I would get a random spark when the whole exhaust system was full of unburned gas--BOOM.
Charley
Big difference from spark at the plugs and spark across the plugs. Just because you have spark from wire to plug doesn't mean its going across electrode
marv
JimmyBb
Member
I just had the same ssymtoms on a 72 TR6 except that it did not fail completely. I was always able to get home although sometimes 25 mph was a challenge. Turned out to be a problem with the float in the forward carb. It would shut down fuel flow sometimes
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
Fanch00 Non-Overdrive Benefits? Austin Healey 10
Celtic 77 MGB Non working tach. MG 4
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
J TR2/3/3A Adjustable vs non Adjustable wheel Triumph 0
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
AUSMHLY SU Damper Cap Vented vs Non-Vented Austin Healey 25
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
C Non-Adjustable steering column questions Austin Healey 14
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Synchro in a non synchro? Triumph 19
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
maxwedge5281 Trafficators, Adjustable vs. Non-Adjustable Austin Healey 14
Jim_Gruber Non LBC but saw my first Civic Type R Yesterday Spridgets 24
Zitch TR4/4A OD Addition to a Non Over-Drive Transmission - my attempt Triumph 11
Rut Interesting non Spridget Spridgets 3
NutmegCT The non-garage garage Restoration & Tools 22
Marla TR4/4A Ballast or Non... Triumph 6
R TR2/3/3A Non Triumph cooling question Triumph 8
B Posting non you tube video? FORUM Navigation Questions 3
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 2
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 0
GTP1960 TR2/3/3A Resistor plugs vs. non-resistor plugs? Triumph 6
nevets interesting piece in the NYT about collector car non-restoration Austin Healey 5
vette Detergent/Non-detergent Austin Healey 19
AUSMHLY Best 7" non sealed headlamp Austin Healey 19
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
CJD TR2/3/3A Adjustable vs Non-adjustable Control Heads Triumph 4
P I need a non-working electric tachometer for parts Spridgets 0
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
vette Detergent or Non-Detergent, Trans/ OD Austin Healey 7
Boggsy64 MGB Starter - Non starter? MG 16
K TR2/3/3A Trunnion spindle cotter pin hole non existent! Triumph 9
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
S WTB: Non-Adjustable Horn Button for a 3000 Austin Healey 6
H horn button for BN6 "non-adjustable" Austin Healey 4
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
johnrip Wedge TR7 non-idle Triumph 4
B Leaded solder vs non leaded solder Triumph 8
