Boggsy64
Feel like I'm on a treadmill running fast and not reaching the end! Now finally car all on the ground and after starting engine last weekend shut back down to replace the block to filter oil hose and repair radiator. All that is done but the engine will just barely turn over. Typical solenoid clicking etc (along with some smoke from where, nothing obviously hot??). Took out the battery and confirmed it is holding a charge, took the battery to Advance Auto to be sure and all is good. Cleaned the battery connections, checked ground to the block and all good (just replaced the transmission mount and ground strap is good). As I drove this thing from Arizona this summer I noticed the starter cranking getting slower and slower each day. I thought the battery must be going bad. Now it barely cranks, actual will not move now. Is it typical for these starters to slow down and eventually grind to a halt (Ha Ha!!). I am thinking brushes?
