mgedit
Bit the bullet and removed nose from TR3 today and pulled the rad to either recore or replace. Rather dismayed at the brown mess that was my new antifreeze solution 200 miles ago! With the rad out what is the best way to flush the system?
I was thinking that I need to remove the block plug and flush system with clean water till it is runs out clear. Guess in top hose and out bottom hose ... is that correct? Was going to isolate the heater and drain and flush that separately using passive flow (pour water though a funnel into heater hose) rather than using a garden hose to ensure not too much pressure in heater core.
Anything else to consider? Seems flush solutions get mixed reviews and not sure if they would be useful with system apart.
Cheers, Mike
Cheers, Mike
