TR2/3/3A 56 TR3 Cooling System
mgedit
Couple of quick questions. The replacement water pipe I bought has a bend in it (believe the original was straight). Assume the pipe is fitted with the "long" end of the pipe at the top. Is this correct? Second, I've always just cleaned pipes and attached hoses with clamps. Anyone using any sealants on joints? Thanks for your help and input. Cheers, Mike
Geo Hahn
Long end to the top (as you say) is how I have fitted mine.
I use some Blue Hylomar on the hose connections, but then I'm using the wire clamps and they can use a little help. In particular the connection of the bypass hose to the thermostat housing might want some of that sticky non-hardening seal like Hylomar as there is no lip on the casting (in fact it is almost tapered).
mgedit
mgedit
Thanks for the help. I plan to use those original style clamps as well. Cheers, Mike
Moseso TR2/3/3A TR3 Cooling System Mystery Triumph 4
martx-5 TR2/3/3A TR3 Cooling System Capacity Triumph 5
T TR2/3/3A TR3 Cooling system Triumph 15
M TR2/3/3A TR3 metal cooling pipe. Triumph 4
S TR2/3/3A Tr3 cooling fans again Triumph 1
mountainman TR2/3/3A TR3 Electric Cooling Fan Triumph 8
C TR2/3/3A More TR3 cooling ideas Triumph 4
K TR3 Hole in inner fenders for engine cooling? Racing 0
K TR2/3/3A TR3 Cooling...Blocking the Bypass Triumph 5
MGTF1250Dave TR2/3/3A TR3 Cooling Triumph 9
bluemiata90 TR2/3/3A tr3 engine cooling Triumph 8
L TR2/3/3A 1960 TR3 cooling???? problem Triumph 9
