TR2/3/3A Connecting Rod Locking Tab Deformation
mastaphixa
Bronze
I'm disassembling a TR3a engine for overhaul and discovered the locking tab washers appear to be deformed. Being new to Triumph engines, I wanted to make sure of what I am looking at. Also, would someone please direct me to a good engine disassembly, reassembly thread? The red book leaves a little to be desired for detail sometimes.
Thanks,
Steve Baker
charleyf
Regarding the locking tabs. My bet would be for the previous person to have caused that deformation when the bolts were tightened down.
M
mastaphixa
Bronze
From the direction they are deformed it's as if the rod bolts were actually loosening. All of the rods exhibit this.
Alfred E. Neuman
Maybe the tabs were re-used? Ends bent down to remove the bolts, then tapped back up after bolts were torqued, but bolt heads ended up in slightly different rotation.
CJD
You should always build with new locking tabs, and they are cheap. It appears your PO re-used the tabs.
TR3driver
Great Pumpkin - R.I.P
Here's a few documents that might help
https://drive.google.com/open?id=0B2H2NJt34OffN2FkZjI2NjktNWJiMy00YWExLWIyNjctOTYzNmI3OTg2ODM0
https://drive.google.com/open?id=0B2H2NJt34OffYTA1NTNmMGUtMTVjMy00NDEzLWJjN2YtNTc1OWRkNjE4MjY4
https://drive.google.com/open?id=0B2H2NJt34OffMWQ4N2EzZGQtNjc0Ny00YmE2LWFiN2UtZWYzMjNjNGFiYzY4
Personally, I've quit using locktabs altogether. Double check that the bolts aren't too long (I've never found any that are, but doesn't hurt to check), then lock them with oil resistant Loctite.
If you want to know why, pick up a copy of the book Carroll Smith wanted to call "Screw to Win". (Unfortunately, better known as "Nuts, Bolts, Fasteners, and Plumbing Handbook")
CJD
In accordance with Carroll, if you ditch the lock tabs, you should tighten to a bolt stretch value rather than a torque number.
TomMull
Sarastro
I've recently been trying to educate myself about bolts, how they loosen, and how to keep them tight. One result is that lock tabs really are not a good way to keep bolts tight, and you may be seeing an example of that. You can replace those bolts with the more modern TR4 stretch bolts, which I'd recommend. The following article is a little whimsical, but I think basically correct:
https://www.mogsouth.com/2018/05/10/keep-it-tight-grass-roots-motorsports-5-10-2018/
M
mastaphixa
Bronze
Thank you all for your input. I think I will order a set of TR4 rod bolts. Am I reading the Moss catalog correctly that part number 320-450 is $16.99. Is that a piece?
TR3driver
Yup. Check the "Where Used" tab, it says you need 8 of them.
Loctite is a bunch cheaper. And as I read it, all Carroll said is that measuring the stretch is a more accurate way of checking bolt tightness than using a torque wrench. There's nothing about it being "required" if you use Loctite instead of locktabs.
PS, a slight inaccuracy in the GRM article. Deformed thread locknuts are reasonably readily available, and not very expensive. I get mine at McMaster-Carr where a box of 50 3/8-24 in Grade 8 (equivalent) is $7.32. https://www.mcmaster.com/92501a430
A box of 100 is $9.22 at FastenerMart. https://www.fastenermart.com/NT163-2622.html
I use them a lot (they work worlds better than Nylocks); but obviously not on rod bolts.
Sarastro
I think the stretch bolts are about $9 at Rimmer; even with shipping, it should be cheaper. They ship really fast, too.
There are a number of effective locking washers in existence. One is called Nordlock; if you search around, you can find lots of types and the results of Junker tests, which show how effective they are.
As for me, I went with the stretch bolts. They are proven, and I don't want to risk my engine by experimenting with other things. I bought some 3/8" and 5/16" Nordlock washers, though, and I plan to use them to replace tab washers in some less-critical places.
CJD
Carroll Smith also says lock washers are useless, because they do not do anything until the bolt is already loose!
Sarastro
Ah, the lockwasher controversy. I've heard the same from other knowledgeable people. And, the opposite from others.
Look at https://www.boltscience.com/, and you will see a vibration (Junker) test showing that the lockwashers are less effective than a properly torqued bolt. But then see https://www.youtube.com/watch?v=IKwWu2w1gGk ; around the 2:35 point there is a plot showing that the lockwasher is quite effective. So apparently they are OK for some things but maybe not others. It would be nice to find some analysis showing exactly what is going on, and under what conditions they are useful or not useful.
I know, I'm a geek, but I still find this kind of thing loads of fun.
CJD
Read Carroll's book and you will get the straight story about fasteners. I have a degree in mechanical engineering, and his is the only book that truly covers ALL the fastening topics thoroughly and correctly. This stuff was studied in depth over a hundred years ago, and the tech has not changed. You and I do not have the time or budget to re-learn the wheel...just go to the book!
I only use lock washers because they are what the factory used and I restore to "original" as much as possible. On my performance stuff I only use hardened, ground flat washers or nothing at all. To me, locktite is for the odd cases, where the factory ignored the rules. For example, Harley uses a million of those tiny steel bolts into aluminum casings. If you try to torque those to proper stretch, they will strip the aluminum case. Thus...lokctite! If designed properly, they would have used studs. And, speaking of studs...another use for locktite if you have a stud that is used a lot and you want to prevent the stud from spinning out of the block when removing the nut, such as our valve cover studs.
Well, I better not get going too much!!
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
R Connecting Rod Big End Specification Austin Healey 4
D connecting rod stamps Austin Healey 1
Csarneson Connecting Rod Bolt Question Austin Healey 3
H TR6 OEM Connecting Rod surprise Triumph 4
S T-Series connecting rod bolts MG 4
T TR2/3/3A ARP connecting rod bolts Triumph 2
B 1275 connecting rod nuts/bolts Spridgets 7
RedTR3 TR2/3/3A Connecting Rod Bolts Triumph 10
Sarastro T-Series TD connecting rod big end diameter MG 4
J TR2/3/3A TR3 connecting rod bearing replacement Triumph 11
PatGalvin TR2/3/3A TR3 Connecting Rod Needed Triumph 10
J TR4/4A Tr 3a & TR4 - connecting rod bolt problems? Triumph 11
Basil Connecting Rod Bolts Triumph 12
KVH Wellseal and Connecting Rod Place Bolts Again Triumph 2
KVH Connecting Rod Bolts Triumph 11
G Can't remove the connecting rod bolts...HELP Triumph 6
J Connecting Rod Front and Back? Spridgets 7
2wrench Connecting rod bushing needs work Triumph 16
D connecting rod/piston compatibility Spridgets 2
tr6web TR6 TR6 Wiper Motor Connecting Rod Triumph 2
Y Connecting rod Triumph 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
R TR4/4A CP-Carrillo or Pauter Connecting Rods Triumph 2
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
Got_All_4 TR6 Ballancing the connecting rods and pistons. Am I lucky? Triumph 4
W connecting distributor wires Austin Healey 2
germanmichel BT7 shroud connecting at front frame rail plates Austin Healey 6
KLUTZ Easiest method for connecting Emerg. brake cable MG 5
G MGB MGB Connecting pin MG 5
D Balancing Connecting Rods Triumph 17
C Connecting Rods and Cams Lotus 1
mjobrien Connecting Rods - Big end Dia Austin Healey 10
G TR 3/4 connecting rods Triumph 6
drooartz Connecting ignition wires Spridgets 10
T TR6 tr6 connecting rods/motorcycle connecting rods Triumph 2
B Rod & Main Bearings Recommendations Austin Healey 10
W Correct Tie Rod Ends Spridgets 0
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
A MGB MGB 1974 windscreen centre rod replacement MG 5
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
DrEntropy Shift rod seal in an automatic? Jaguar 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Healey Nut Cross Rod Correct Length Austin Healey 14
7 General TR Hot rod Triumph 0
Healey Nut BT7 Panhard Rod Austin Healey 28
