The float levels are set the same as you would the earlier model, except on carbs using plastic floats. As I stated earlier, the manual is incorrect on the HD8s float levels it should be 5/16ths. The reasons are :1) with the float being at 7/16ths the fuel level is lower so engine cranking is longer to pull fuel up. These cars are cold blooded and need lots of fuel on cold starts.2) with the float level set at 7/16ths, there is less fuel in the float bowl which could cause the car to run out of fuel when running at high RPM causing a lean mixture and a loss of power. I use the 5/16ths round bar to set the float . The bar goes between the float bowl cap and the float leaver arm. I believe this is what the manual shows but I don't have a manual in front of me. Remember to measure where the float hits the arm.
Elevation above sea level will change the settings required. Generally service manual instructions are based on being at sea level.
