cold air duct 100
dh100m
Member
I have a cold air inlet duct for my 56 100 and the flap operator is on the underside which means the cable would have to go over the top to connect this is a used item i bought
so i do not know if this is original help would be appreciated
AH100M
For a LHD car the operating lever for the cold air valve should be on the top of the valve. Is your car LHD? Maybe you got a valve from a RDH car (not sure if they're different)or a different car altogether? The valve is not easily disassembled so what you have probably cannot be made right.
British Car Specialists sells new ones for about $185.
musme
You get the same valve in head for healeys in england for 70 pounds including shipping to the uS. This is around 110 dollars, versus 185 !!
K TR2/3/3A Anyone running a cold air duct to the carbs? Triumph 15
RAC68 Cold Air Bilge Blower update Austin Healey 13
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
M BN1 - Question about cold air box Austin Healey 6
TRMark TR4/4A Cold air intake system Triumph 1
Morris Cold Air Intake Spridgets 2
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
AH100M 100m/100 Le Mans Cold Air Box grommets Austin Healey 5
J Replacing the cold air intake hose Austin Healey 22
E TR6 TR6 Cold Air Induction - Mixture Triumph 2
A cold air box? Austin Healey 25
AH100M 100m Cold Air Box Grommets Austin Healey 2
PAUL161 CAR COLD? How About Recirculating Hot Air! MG 8
C Cold Air Box for a 6 cylnder ? Austin Healey 13
L K&N Cold Air Intake MG 7
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
F TR6 Pegged out hot while cold Triumph 7
B Cold Start Problems BN7 Austin Healey 21
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
N Running Cold Austin Healey 12
M Cold start problems Austin Healey 33
D it's cold and i'm bored... waiting for parts... Austin Healey 11
M Starting from cold Austin Healey 2
F TR2/3/3A Starts Cold, Not Hot Triumph 12
R Very Difficult cold weather starting problems! Austin Healey 21
K Hard Start, runs poorly when cold Spridgets 10
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
S Hard starting on Webers from cold Austin Healey 12
Lutz Kramer Problem starting the cold engine Austin Healey 16
drooartz MGB Must be the cold -- MGB will have a nice Xmas MG 7
M running cold Triumph 8
J Cold Starting on a Series II Jaguar 5
S Cold galvanizing zinc spray Restoration & Tools 5
N Cold Plug site shutdown! Other British Cars 19
tahoe healey How cold would you drive? Austin Healey 16
V hard start when cold Austin Healey 7
aeronca65t TR2/3/3A TR3-cold tires Triumph 2
H Cold blooded animal Triumph 21
nevets OD sluggish when cold Austin Healey 15
S Cold Start issue MG 4
tweety Cold Start thoughts Spridgets 6
drooartz A great [cold] drive today Spridgets 5
PAUL161 Just Brought "B" Out Of Cold Storage! MG 14
Morris Cold Start reality check Spridgets 10
theleisure Cold Weather, Oil Pressure Spridgets 10
T 100M Cold Airbox Filter Austin Healey 29
Thor Suggestions for hard starting 1500 when cold Spridgets 5
