Cold Start Problems
EMGEBE
Over here in Aus, Winter has well and truely begun, and the cold starts are becoming a real PAIN IN THE ###!!!!!
The B now is running better than it ever has, the tune is GREAT, doesnt blow smoke, now essentially all the internals are BRAND SPANKING NEW!
I'm just a bit stumped as to why its SOOO darn HARD to start.
CRANK CRANK CRANK CRANK CRANK...
It only seems to fireup when i stop cranking the starter... my mechanic says its a problem with the barrel of the ignition switch.
What u guys recon?
Cheers Jarrod /ubbthreads/images/graemlins/crazy.gif
/ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/devilgrin.gif /ubbthreads/images/graemlins/driving.gif /ubbthreads/images/graemlins/cheers.gif
Mike H
Try bypassing the ignition switch.
Run a jump wire from an always on power source.
Then try starting. If the same things happens, it is not the switch. If it starts, then the switch is the problem.
Oh, you will have to disconnect the wire to turn off the engine once it starts.
Nunyas
If the problem is only there when the car is cold, then I'm partial to the choke not functioning properly. Just a thought, does your car have automatic choke, or does it have manual choke?
If you have auto-choke, I believe you may have to press the pedal to the floor then take your foot off the pedal before starting. That's how the single ZS carbs are anyways (do twin SU carbs have auto-choke, and do they work the same way as the ZS?). For manual choke, I'd make sure the pull handle is actually enguaging the choke on the carbs.
EMGEBE
EMGEBE
Cheers mike.
Mite give it a whirl this arvo /ubbthreads/images/graemlins/thumbsup.gif
Nunyas... Ive got twin SU's in this, but theres nothing wrong with my choke and yeh SU's have manual choke
Keoke
Yep EMGEBE, But like that fellow,Nunyas, said be sure that the choke is adjusted properly. If it isn't set up right you can crank on SU's and that bugger won't start for a long time. Try this to check the choke setting, instead of just pulling it out once, give it initially two pulls and see if it starts sooner.If it does the choke needs to be visited and given some additional attention.--FWIW /ubbthreads/images/graemlins/cheers.gif--Keoke
B Cold Start Problems BN7 Austin Healey 21
M Cold start problems Austin Healey 33
X cold start problems Jaguar 7
K Hard Start, runs poorly when cold Spridgets 10
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
V hard start when cold Austin Healey 7
S Cold Start issue MG 4
tweety Cold Start thoughts Spridgets 6
Morris Cold Start reality check Spridgets 10
J 1985 Jaguar XJS - Cold start problem, help needed Jaguar 24
D Oil burning at cold start Austin Healey 17
C Cold start/Choke? Triumph 3
stradi Stromberg Cold start issues Triumph 11
bluemiata90 Wedge TR8 adjust cold start idle and warm temp idle Triumph 3
bluemiata90 zenith stromberg cold start adjustment Triumph 5
t-rocks69 cold start injector Triumph 11
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
F TR6 Pegged out hot while cold Triumph 7
RAC68 Cold Air Bilge Blower update Austin Healey 13
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
N Running Cold Austin Healey 12
D it's cold and i'm bored... waiting for parts... Austin Healey 11
M Starting from cold Austin Healey 2
F TR2/3/3A Starts Cold, Not Hot Triumph 12
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
R Very Difficult cold weather starting problems! Austin Healey 21
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
M BN1 - Question about cold air box Austin Healey 6
S Hard starting on Webers from cold Austin Healey 12
Lutz Kramer Problem starting the cold engine Austin Healey 16
TRMark TR4/4A Cold air intake system Triumph 1
K TR2/3/3A Anyone running a cold air duct to the carbs? Triumph 15
drooartz MGB Must be the cold -- MGB will have a nice Xmas MG 7
M running cold Triumph 8
J Cold Starting on a Series II Jaguar 5
Morris Cold Air Intake Spridgets 2
S Cold galvanizing zinc spray Restoration & Tools 5
N Cold Plug site shutdown! Other British Cars 19
tahoe healey How cold would you drive? Austin Healey 16
aeronca65t TR2/3/3A TR3-cold tires Triumph 2
H Cold blooded animal Triumph 21
nevets OD sluggish when cold Austin Healey 15
D cold air duct 100 Austin Healey 3
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
drooartz A great [cold] drive today Spridgets 5
PAUL161 Just Brought "B" Out Of Cold Storage! MG 14
theleisure Cold Weather, Oil Pressure Spridgets 10
T 100M Cold Airbox Filter Austin Healey 29
