Clutch shudder problem in Morris Cooper S
G
Can any offer any advise on how to fix a continuing clutch shudder problem in a Morris Cooper S. Any responses would be welcome.
V
vagt6
Steve's probably correct. I had the same problem, it was oil on the pressure plate.
Maybe you'll get lucky and it will stop. Drive it for awhile, if it's not too bad, and see if it improves.
G
Thanks for the replies. There does not seem to be any oil problem however. Any other ideas?
Steve
Platinum
Could the clutch plate have become glazed? Dumping the clutch for racing-style getaways might do this. From your reply it would seem that you have the thing apart at the moment, if so does it look shiny on part of the plate's face?
Super 7
If it is not oil, then it could be uneven wear on the pressure plate and flywheel.
mongoose
Sorry, guys, I have to disagree with the oil. Oil would tend to make it slip, progressively getting worse; I've been there a few times with an early 850 "wet" crank.
Shuddering most likely caused by glazed flywheel or pressure plate, or even the disc itself. Resurface flyheel, replace pp and clutch disc should cure it.
[ QUOTE ]
Could the clutch plate have become glazed? Does it look shiny on part of the plate's face?
[/ QUOTE ]
Or bluish, orangish, brownish in color? Unevenly around the flywheel? That would indicate local hotspots (no, not swinging nightclubs /ubbthreads/images/graemlins/wink.gif )where it's become overheated.
G
Thanks for the replies. However none of the above mentioned suggestions appear to be a problem. I have a few other theories and I will post what the solution is if I find it. Any other (perhaps more obscure) suggestions would still be welcome.
piman
Hello Ivan,
check the condition of the engine steady bar, its mounting on the bulkhead and the bushes.
regards,
Alec
mongoose
Ah yes, piman might be on to something. Completely forgot about that. I think I might have some extra (new) poly bushings if you need them.
WJM
I had this problem. Changed the steady bar rubbers and all was well. Good luck John
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
S MGB clutch replacement MG 7
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
D BJ7 Clutch Austin Healey 6
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
