After installing the new throttle vertical and horizontal linkage, plus new SM needles and .100 jets, I'm trying to re-set the mixture.
Throttles balanced. Fast idle screw full out (not touching cam). Mixture nuts screwed full in, then backed off (enriched) two full turns. Engine starts immediately at crankover. Idle at 800 warm. Slight whitish "smoke" from exhaust. Idle very lumpy - "blmp blmp blmp etc." - sorry for the highly technical sound description ....
Lift piston 1/8", speed increases slightly, turn in one flat to lean. Lift piston, speed still increases slightly. Repeat ad infinitum.
I can actually get the mixture screws all the way up (full lean) and still the engine runs with that "lumpy" sound and feel. Lift the piston, still increases rpm.
Owners manual, Haynes, and Standard manual refer to "clear exhaust" or "black exhaust". Also say to lean mixture if idle increases when piston is raised. I've got neither. Manuals say mixture is set when exhaust is clear and idle slightly raises *then returns* when piston is slightly raised.
What does the whitish/greyish exhaust tell me? What am I missing in the mixture adjustment?
Thanks.
Tom
Thanks.
Tom
