Bugeye rear wheel advice needed
R
Rakos
Hi, I rebuilt the hubs. Major issue was getting the old oil seals out. Careful: I chiseled out all the rubber and it seemed like the steel seat was left but new seal would not go in Turns out the seals have a steel rim (L shape cross section) which was still left in the housing. Got it out with an aluminum chisel and it all fits fine.
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
E Bugeye Wire Wheel Rear Spridgets 22
Geo Hahn Bugeye Rear Wheel Studs Spridgets 2
Keith_M Bugeye rear leaf springs Spridgets 19
Gerard Bugeye bonnet and entire rear clip Spridgets 4
TulsaFred Bugeye Generator rear bush issue Spridgets 8
R Bugeye rear bumperettes Spridgets 8
Keith_M Bugeye beading and rear cowling Spridgets 9
P Bugeye rear brake springs??????? Spridgets 5
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
I Bugeye rear lights not working Spridgets 11
DanLewis Checking condition of rear springs on a Bugeye Spridgets 17
M Bugeye rear brakes Spridgets 3
P BUGEYE REAR TUBE SHOCK CONVERSION Spridgets 0
B Bugeye rear brake assy? Spridgets 15
DanLewis Bugeye rear brake upgrade - hubs now rubbing Spridgets 3
Gerard Spax rear shocks on Bugeye Spridgets 12
6 Rear brake banjo bolt/61 Bugeye Spridgets 3
I How do I remove a rear axle in a bugeye sprite? Spridgets 27
drooartz Source for Bugeye top - rear bar Spridgets 13
Trevor Jessie Bugeye rear ends 100-6 [the result video] Spridgets 12
Trevor Jessie Bugeye rear ends 100-6 [needs a bonnet] Spridgets 11
M Bugeye gearbox rear seal Spridgets 7
T BugEye - identifying rear axles[?] Spridgets 0
T Bugeye rear jacking point not including axle Spridgets 3
T Reference pictures of Bugeye rear suspension Spridgets 2
M Bugeye rear Spridgets 6
M Bugeye rear end noise Spridgets 14
T Bugeye rear bush question - bolt is stuck and am I Spridgets 12
T Correct rear bushings for 1960 Bugeye? Spridgets 5
longbridgehealey rear bugeye brakes for dummies Spridgets 11
Hairyone bugeye rear springs Spridgets 1
M Rear bugeye upgrade advice Spridgets 18
toysrrus Bugeye: "FRONT TILT OR REAR TILT"? Spridgets 16
Hairyone bugeye rear brake shoes Spridgets 5
drooartz Late rear brakes, Bugeye -- rods adjusted Spridgets 5
msoylemez Wanted: Original Bugeye Rear View Mirror Spridgets 12
M Bugeye rally spec rear springs? Spridgets 9
E Bugeye Rear Hub Removal Spridgets 5
Ohiobugeye Bugeye Rear Wiring Harness Route???? Spridgets 1
abarth69 Square body sprite with Bugeye rear bumpers Spridgets 14
I Bugeye hardtop rear window removal Spridgets 2
ncbugeye Bugeye Rear End questions Spridgets 8
Jayrz Bugeye rear onto square sprite? Spridgets 4
Atrus Bugeye rear overriders Spridgets 4
T Filling rear Bugeye shocks - any tips? Spridgets 7
jlaird The guy with the banged up Bugeye rear end Spridgets 2
Geo Hahn Bugeye Rear Axles Spridgets 6
