Before I put engine back
middie
I'm starting to put all the "bits" onto the reco'd engine before I put it back into the car.
I've put in a new clutch and pressure plate, and was wondering whether there is anything else I should replace before I put it back? I'd hate to have to take the engine out again because I missed some sort of seal or something.
Wazza
Looks good!
did you change the pivot for the clutch arm?
m
Does look good! I changed the motor mounts at the same time. Also assuming you aren't using the air pump and pollution stuff, you can take off the oil filter adapter and just run the filter straight into the block. Finally, though this isn't strictly engine install related, the sooner you fit the oil pressure hard line the happier you will be - don't ask me how I know. In that vein, installing brake lines first (if you haven't already)will make your life easier.
You took the speedometer cable out with the engine! That's genius! I always try to install it once the engine is back in the car. What a pain!
+1 on that. I would have never done that. sucker is a real pain to put back on once in the car.
m
Throw out bearing I hope.
Thanks everyone. I will have to revisit that pivot pin - I looked at the throw out bearing and just the fact I had to press it out sort of "scared" me. Guess I'll have to have a go at it.
Didn't give the oil filter idea a thought, sounds good.
wazza
Throw out bearing is not a press anything. Has a couple of small clips to hold it in place.
Look again.
Don't do that unless you change the mounts. Old mounts sag down to low and the filter hits the steering shaft. I tried to be cheap and not change my "still good' motor mounts while it was out only to have to change them BOTH two months later. The cost or time didn't bother me, it was missing a good drivng day.
Thanks gentlemen.
Jack - mine is a 1979 California car, perhaps this is why the manual tells me I have to press out. Would be much easier with a couple of clips.
JP - "remove oil filter adapter and just run the filter straight into the block" I'm hoping the adapter is the shiny bit in the below picture. I reckon I'm going to have to take it off anyway, because I think the mechanic put it back on upside down????????
JP - "sooner you fit the oil pressure hard line the happier you will be - don't ask me how I know". OK, I won't ask you, but will ask just what the hard line actually is???
Wazza
Duh, its a 1500. yep pressed in but no big deal.
middie said:
Thanks gentlemen.
Wazza
Yes the adapter is the shiny piece and yes i believe you have it upsidedown - mind you you ARE in Australia. The hard line is the oil pressure line that goes from the oil pressure guage through the firewall to the junction that leads to the oil pressure hose that screws into the block. I can't remember if there is a place to screw in the fitting that goes into the block on the other side of the engine saving you have to reroute line around the engine. I put mine in later and then discovered it was supposed to go under the wires and the brake lines and the windshield washer hose - was a pain to fit at that stage.
"mind you you ARE in Australia." :lol:
Correct JP, and you should see the trouble I'm having stopping the oil from running out of the oil filler cap . . . :wall:
Wazza
Wazza
Wazza
took me a minute- But now YOU OWE me a keyboard.. :cheers:
m
JP, he doesn't have a hard line. He has a three prong sending unit (CA)....that you can no longer buy....that you have to replace with a single wire sensor from a small block chevy.......that if you bought it from Advance will leak in a few hundred miles.....that they will be mad at you if you change it right in front of the door......because oil leaked out everywhere......which wouldn't have happened IF THEY SOLD DECENT PARTS....
Warren, unscrew the filter nipple out of the adapter and then screw the nipple straight into the block.
IIRC it won't clear if flipped upside down.
JP, did you do direct before or after me?
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]
Yes the adapter is the shiny piece and yes i believe you have it upsidedown - mind you you ARE in Australia. [/QUOTE]
So now you understand why Australians never wear kilts. :nonono:
Wazza
jlaird Before I put in classifieds Spridgets 36
bugedd Before I put it on ebay.... Spridgets 0
B Before I put the heater in my 57... Triumph 10
Hap Waldrop Caution: Put your shades on before viewing :] Spridgets 10
tr7andtvr 280i For Sale [before I put it on ebay] $6500.00 TVR 1
J before I put this in my differential Triumph 8
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
DrEntropy Before they were Vintage Racing 0
JPSmit Ford Taunus - never seen on in the flash before Spotted 4
B Before and After Pics Longbridge 100-6 Austin Healey 5
D General TR Fuel filter before the pump. Triumph 2
JPSmit Hagerty Prediction - Cars to buy now [before they get expensive] Spridgets 1
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
TomMull Why didn't somebody tell me about this before Restoration & Tools 5
P T-Series MGTD - before and after MG 3
D TR2/3/3A Excessive cranking before it starts. Triumph 47
D Prepping Floors Before Installing Interior Restoration & Tools 6
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
J Wedge TR8 research before purchase Triumph 16
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
simon1966 Before and After Austin Healey 2
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
C Static timing before engine start up Spridgets 4
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
Popeye Engine starving for fuel before tank is empty - 2001 Audi TT Other Cars 5
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
T TR2/3/3A Before and after lever shock absorber pictures Triumph 12
R Last minute check before engine install Austin Healey 26
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
RickB Questions before seeing insurance appraiser Spridgets 12
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
B Spitfire before i swap this od transmission into my mk3 what would you do? Triumph 11
DNK Never Seen One of These Before Other British Cars 3
hilsideser Never seen one of these before... Spotted 5
Lukens TR2/3/3A Before I remove my steering box... Triumph 10
apbos What can I bolt to the engine before I install it? Spridgets 12
DerekJ Ever seen wire wheels like this before? Austin Healey 5
Lukens TR2/3/3A Think I'll add a fan on TR3 before I need it. Am I being overly cautious? Triumph 13
L Adjusting the bows before top installation Austin Healey 2
P Thanks Basil!! Spridgets before Sunbeam! Spridgets 1
F Somebody buy this owner's manual before I do Austin Healey 28
RickB Before and after top with 303 Aerospace protector Spridgets 8
bugedd Last chance before it becomes a planter Spridgets 11
JPSmit Before and Afters Restoration & Tools 4
mrv8q The Night before Christmas Triumph 2
regularman Before I would pay $2900 for this bonnet Spridgets 6
