battery drain
Sopwith_Camel
ok my xj x300 drains its batter in hours how do i fine the leak??
steve
mezy
Remove the positive lead from the battery.
Place a multimeter set on ohms between the positive lead and the earth lead.
Then you can start checking things to see what is pulling the battery down.
Pull fuses one at a time, if the resistance changes dramatically then you will know which circuit the drain is on.
Disconnect the alternator, i have known them to drain a battery in a very short space of time,
In an ideal world the ohms reading should be as close to zero as possible, but on a modern car there will always be something
drawing from the battery.
Sopwith_Camel
Sopwith_Camel
thank you.
yes I replaced the Alternator. and its been back to the shop to check.
NutmegCT
Other than an electric clock running 24/7? Until you find the problem, put on a battery disconnect. Something like:
Sopwith_Camel
Sopwith_Camel
yes all my MGs have that. but the issue with the XJ is that the battery is in the trunk and the key has a chip that needs electricity
mezy
Which model xj do you have sopwith, I have the xf and that also needs battery to open the boot, but there is still a key lock also up under the chrome trim. probably need to stand on your head to see it
Sopwith_Camel
Sopwith_Camel
this is a 95 XJ its my one modern.
I have rewired a spridget and a B but they are alot simpler.
maynard
Be aware that many computerized cars do not shut down completely for up to 45 minutes. If you are measuring draw, keep it in mind, Also some cars do not shut down if the bonnet is open, Us extension leads so you can shut the boot/bonnet.
mezy
My jag has that but it was left for a month while we were on holiday, started first press when we came back
Sopwith_Camel
Sopwith_Camel
ok finaly going to try this, dose it have to be the postive lead? do i need the key ON ?
Sopwith_Camel
Sopwith_Camel
hail, so im back in, i have the multimeter on 200 om and its stedy on 1 as i have poped the fuses, half way through.
steve
donbmw
When I have been looking for a drain I do the same test but the meter is set on DCA 200m.
Sopwith_Camel
Sopwith_Camel
ok i will try that i have now pulled each of the Fuses one by one. in the 5 fuse boxes.
do i need to pull the relays?
i could be useing it wrong it is reading 1 with 200 om before i connect it to the battriy. I though i had change on the right front fuse box but it did not replicate.. weather is much better. but i need to finish my grading.
donbmw
What I see wrong from the way I have checked for a drain. #1 meter leads between the battery post and the wire you remove. #2 meter is not set to ohms but to DCA Ma 20m or 200m.
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
Tinkerman TR2/3/3A TR 3A Battery Box Liner. Drain Holes? Triumph 3
vping Battery Drain MG 10
N Parasitic drain on battery Jaguar 1
athenssprite Battery drain Spridgets 5
jjbunn Battery drain after turning engine over Triumph 7
PATR8 How do you find a battery drain Triumph 14
davidk TR6 TR-6 Battery Drain Triumph 14
M Radio battery drain MG 4
M 90 XJS V-12 Battery Drain Jaguar 22
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
