battery drain
Sopwith_Camel
Sopwith_Camel
ok i have one lead on the post and one on the Neg cable.
both the DCA 20m and 200m tick down to Zero so i just keep pulling fuses till something happens.
do i need the key in the first position? or since the battry drains while parked that is not part of the issue.
steve
equiprx
Key should be out.
That's the situation where the issue is.
Platinum
Glovebox lamp is another gremlin to look for. Dickey switch or mis-adjusted and not switching off with lid closed.
"Modern" radios are another draw, always some voltage to keep the memory settings.
A 12V test light works instead of a VOM, too. And easily seen from the other end of the car. Bright= full draw. Dull glow= radio, alarm trigger circuit, etc.
Sopwith_Camel
Sopwith_Camel
no luck so it could be the radio thats modern.
but also the new alienator (its been back to the shop and checked) is not charging the battry enough so it drive it for a half hour its dead.
donbmw
What is your battery voltage when run at idle and above.
Sopwith_Camel
Sopwith_Camel
let me re-test im not sure if that was before the new altinator
mezy
steve
Sorry been o work or our days, dont have much chance to ollow up on posts when im at home, her indoors keeps me busy, :sneaky:
you need to remove positive rom the battery, connect one lead to the positive cable and one lead to the negative lead,
this way you have removed the battery rom the system and are reading ohms draw rom the possitive to ground.
i you connect to the battery post you are only reading resistance throught the battery.
darn laptop playing up here the £rickin e£ not working.
Sopwith_Camel
Sopwith_Camel
well it wont start. the battery is full even tried the jump kit.
turn the key and nothing, usably if the battery is down it trys to fire. the relays are clicking
where is the starting relay??
steve
Sopwith_Camel
Sopwith_Camel
well the key dose nothing it ran in december. the dash lights turn on the radio comes on and the interior lights.
I found the starter relay, I dont seem to get the starter relay out, not sure the trick on these, dont want to break it.
if its the key im screwed i only have one.
an video on youtube said it could be the body control module behined the glove box. could that be hte heart of all my issues?
Sopwith_Camel
Sopwith_Camel
ok I got the relay out the wires going in are white and white with a brown trace, so if its like the B or the Spridget that should be the one.
ill try and trigger it tomarrow. although sun dose set after 10pm tonight.
Sopwith_Camel
Sopwith_Camel
ok if its not the starter relay
how do i re pair the key to the car?
Sopwith_Camel
Sopwith_Camel
ok the immediate problem is its in some sort of safe mode and the keyfob only works intermittently ( yes, fresh batteries )
I have the car on the charger again.
LarryK
Unplug a fuse at a time or all and add as youbcheck. Do not forget modules at each headlight and tailight.
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
Tinkerman TR2/3/3A TR 3A Battery Box Liner. Drain Holes? Triumph 3
vping Battery Drain MG 10
N Parasitic drain on battery Jaguar 1
athenssprite Battery drain Spridgets 5
jjbunn Battery drain after turning engine over Triumph 7
PATR8 How do you find a battery drain Triumph 14
davidk TR6 TR-6 Battery Drain Triumph 14
M Radio battery drain MG 4
M 90 XJS V-12 Battery Drain Jaguar 22
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
