Alternate Alternator?
Dadandson
Is there a domestic, I know nothing is domestic anymore, alternator that I can use to replace the Lucas alternator on my 74 1275? Something I can pick up at a local parts chain? Thanks
Sarastro
Bosch 13107 should be pretty close. This is a 55 amp unit used on a 78-80 Ford Fiesta. I used it for the alternator conversion on my bugeye.
Also, look for a listing for a 74 MG Midget on the Autozone site or someplace similar. You can get an alternator that is almost identical to the old Lucas ones. It's still only 35 amps though.
Atrus
I put a Delco single-wire (off a late 70's camaro) on my 1275. Took a small (and, seriously, I mean small) amount of grinding on the alternator mounting flange and a $10 or $15 Mr. Gasket bracket.
All you need to know is HERE.
JPSmit
I used the delco - love it! and with the 1500 there were no modifications other than the electrical plug - I even used the original brackets
Dadandson
Dadandson
I think I will give the Delco a try. Thanks
Dadandson
Dadandson
Is the existing wiring and regulator sufficient to have the 32 to 64 amp increase? No smoke, right?
Atrus
should have an internal regulator. I don't use that box on the firewall anymore with the Delco unit.
regularman
You won't need the regulator and the wiring will handle it easy. The only wire taking the extra current is the one from the alternator to the battery, its the thick brown one.
Dadandson
Dadandson
Got it. Thanks
SD Bugeye Alternate alternator Spridgets 20
SD Bugeye Alternate alternator Spridgets 5
texas_bugeye Alternate Alternator Spridgets 3
kodanja An Alternate Alternator? Triumph 88
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
T Front Flip Hood Alternate Latching Spridgets 12
SherpaPilot TR6 Alternate Door Jam Light Switch Triumph 4
aeronca65t Alternate Detroit Auto Show Other Cars 5
Jim_Gruber VIN number alternate locations - Somewhere by front suspension????? Spridgets 20
H alternate to plating? Austin Healey 7
blueosprey90 MGA An Alternate Sway Bar Link for the MGA with MGB Sway Bar [ a repost] MG 1
tomshobby Alternate routes for the 50th in Wisconsin Spridgets 2
T Weather and Transportation - alternate thinking? Spridgets 43
boeingpilot TR4/4A Alternate differential for TR4A Triumph 4
bill_powell Alternate Seats [again] Spridgets 17
Nunyas Alternate "basic" transportation... Other Cars 29
Ed_K Alternate way to cure fiberglass resin ? Austin Healey 14
F Alternate Seats? Spridgets 17
norcalnewb Alternate Sprite Interior Colors Spridgets 7
S Wedge Alternate/After Market Wheels for TR7 Triumph 6
T TR6 Alternator wiring Triumph 3
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
