Alternate alternator
SD Bugeye
So back about ... 11years ago on a trip the alternator from Lucidus Lucas died after being in the car for about a month.
Went to NAPA bought a single wire AC Delco unit for a Monte Carlo didn't go any faster but it has worked religiously and have never given it much thought until a friend was looking in the engine bay and said it looked totally out of place being half the size of the engine.
I was looking for a new one for the elcamino I have as it is weak gen light is just starting to glow .
found one on amazon then an ad popped up for a single wire small form from DB electrical.
Db Electrical And0212. 66 bucks bought it for the the bugeye.
And will put the beast in the ElCamino.
So new project it tiny 5lbs. Into the sprite @35-40 amp. Plenty.
have to make a trip to Canada but will share on the install when I get back
Sarastro
nomad
Nice find SD Bugeye...The Kubota alternator has been brought up before. I particularly like the small skeleton framed alternator's...I'm running one off a Ford Festiva in my Datsun engined Midget. They are all hooked up about the same so what ever works.
Kurt
SD Bugeye
SD Bugeye
Ok alternator showed up today.
packaged better than some wine I have ordered
weighs in at about 5lbs
nice finish on the case looks good
in the box is the test sheet sort of like a grocery recept with perforated side holes tractor feed printer
it has the actual test rpm =amps results and a graph of the run.
i have never bought an alternator that has come with this info sheet before
14.29 volts 54 amps peek @ 5,000 rpm
14.25 volts 14 amps @ 1500 rpm
regulator turn on 1230 rpm
regulator active 523
max watts 712
so its 5 degrees I'm waiting till I get back from Winnipeg before I do anything with it.
Jim_Gruber
And is this a Kunitz alternator? Price is right. Need to figure out how to hook up a one wire alternator to IGN lamp on my Speedhut Tach. I may need to go 3 wire.
Gerard
You can't wire an ignition lamp with a true 1 wire; you need to wire a volt meter if you want any feedback as to what it's doing.
Jim_Gruber
All I want is to be able to turn on the IGN lamp if things go awry. Early warning before overheating occurs.
nomad
I think you are out of luck, Jim. That is the reason I avoid the one wire. First one I encountered I have on a tractor with a ammeter.
Kurt
Jim_Gruber
Well then I'll go three wire or whatever just so I can get the IGN lamp to work.
Jim, I'm not an electronics guru, but I would think it would be a rather simple circuit with few components to make a box to turn on a lamp when voltage is imbalanced. There may already be such a thing in the street rod world. I'll check my catalogs.
SD Bugeye
SD Bugeye
Wiring for my new alternator to idiot light
Looks easy enough I'll let you know the cut in and out voltage in run and if it lights up brite as expected with the ingnition on not running.
the cut in - out rpm is 523 but crank pulley is way bigger so not sure if I can coex to run at a low enough speed to cut out the charge point
may just loosen slip the belt?
wait and see.
I did this years ago on my MGB... used a early 90's Saturn alternator. About 90 or 110 amp, a little shorter than the Lucas one, and the only mod needed was to clock the case so the brackets lined up.
Jim_Gruber
Curious to see if this works. That is the diagram I was looking for. What is the part # for this alternator from this site?
Jim_Gruber
Thanks for the update. I see how the circuit works I do believe. Idiot light can get power from battery if alternator cross out or belt bread. Don't you need a diode in the to prevent Voltage going back to alternator from fuseblock ? Just let me know if it works . Thanks .
SD Bugeye
SD Bugeye
So all done .
took it for a spin bit nippy out but dry and no snow or ice!
a rare ocasion here this time of year.
So it charges,ing. light comes on, can't call it GEN anymore
and goes out.
and does look like an after market turbo strap to the eng. like the delco remy 70 's alternation did.
had to a little milling on th emoting flange to get the pulleys center to center correct but not a huge deal.
before picture
SD Bugeye
SD Bugeye
After picture
whew like it much better.
why did I not do this years ago..
Jim_Gruber
And here is why I have been asking. A little more bling from Speedhut arrived today. This artwork is now available. Speedhut GPS Speedo, eliminates the need for a conversion speedo drive wit my Datsun 201 5 Speed. The Matching Tach featuring an Ignition Lamp supports a 3 Wire Alternator. Will wire so RED IGN lamp glows if I lose the fan belt or Alternator. It took 2 1/2 months to get this Custom Austin Healey Script Artwork from Speedhut. a subtle piece of Bugsy IV's Build, but I think the wait was worth it. These will be on the shelf for a bit awaiting new Wiring Harness and Alternator. But just like the Creative Spridgets Rear Disc Brake Brackets, a bit of bling that is a thing of beauty. View attachment 46797View attachment 46798
SD Bugeye Alternate alternator Spridgets 5
texas_bugeye Alternate Alternator Spridgets 3
Dadandson Alternate Alternator? Spridgets 12
kodanja An Alternate Alternator? Triumph 88
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
T Front Flip Hood Alternate Latching Spridgets 12
SherpaPilot TR6 Alternate Door Jam Light Switch Triumph 4
aeronca65t Alternate Detroit Auto Show Other Cars 5
Jim_Gruber VIN number alternate locations - Somewhere by front suspension????? Spridgets 20
H alternate to plating? Austin Healey 7
blueosprey90 MGA An Alternate Sway Bar Link for the MGA with MGB Sway Bar [ a repost] MG 1
tomshobby Alternate routes for the 50th in Wisconsin Spridgets 2
T Weather and Transportation - alternate thinking? Spridgets 43
boeingpilot TR4/4A Alternate differential for TR4A Triumph 4
bill_powell Alternate Seats [again] Spridgets 17
Nunyas Alternate "basic" transportation... Other Cars 29
Ed_K Alternate way to cure fiberglass resin ? Austin Healey 14
F Alternate Seats? Spridgets 17
norcalnewb Alternate Sprite Interior Colors Spridgets 7
S Wedge Alternate/After Market Wheels for TR7 Triumph 6
T TR6 Alternator wiring Triumph 0
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
